Question about Canon CNN-CP330 Thermal Photo Printer
My cp-330 canon compact photo printer only prints 1/2 the picture, I have treid new ink cartidge and paper, still it doesnot work.
Printer will not print
1.remove the waste ink pad,and wash with water
2.Down load the free "ssc service utility" software (help of google search)
3.install the downloaded software in your system
4.then reset all chips using the software(especially counter chip)
5.now the printer will print properly
Mar 09, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
The printer is not pulling the photo paper from the cartidge what can I do
Are you putting the paper on the front tray? The selphy takes the paper from the front all the way out the back before it starts printing. If it doesn't go in, you may need to clean the roller in the front with a damp towel so it can grab better.
Sep 30, 2009 | Canon SELPHY Compact Photo Printer
Streaky pictures
hi, your head has damaged/need replacement. Try to clean it once again
thanks
Aug 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon thermal printer cp-330
search for canon cp-220. There is an explanation of the problem. Good luck.
Nov 27, 2007 | Canon CP-330 Thermal Photo Printer
Canon CNN-CP330 Thermal Photo Printer Logo
174 people viewed this question
old marine
old marine
