Question about Panasonic PT-50LC13 50" Rear Projection HDTV
How do i take out pt50lc13 bulb out of housing i got the housing out of tv but i only bought the bulb to replace old
    Problem Solver:
How to make pt950 reagaon free
Posted on Sep 26, 2009
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Changed lamp green light comes tv plays for about 1 or 2 minutes tv goes blank red flashes 3 times.
Not 100% sure but I am currently looking into this. 2 things it might be which are most probable. I replaced my lamp a few years back with no issues. This time around I figured I'd be proactive and bought a new lamp as my current one was going dim. Not unusable but I could tell. Lamp arrived and I put it in. Started up, great! Then after a few minutes it shut down and the red LED would blink 3 times. I removed the lamp and replaced it after unplugging the tv and turned it on. This time it ran about 20 minutes and same thing! Tried a third time and had the same thing. So I put the old bulb back in, and this time it didn't even turn on! I removed it and with a flashlight looked in there. There are two safety switches. The first is a very small pressure switch at the base of where the bulb interfaces to the TV. That switch ensures the bulb housing is seated. Secondly there is a switch in the rear side where the second door with the lever lock is. When you rotate it the switch is engaged. I replaced the housing carefully and made sure everything was tightly seated. The tv has been on for about an hour now no issues with the old bulb.
I have two theories and am leaning toward the second one I will suggest. One is that the bulb is somehow overheating as it is newer and brighter, or is somehow defective. The other theory is that as the bulb heats up the switch might be getting dislodged. I am leaning towards this given that it is working with the old bulb. But I am not certain. Soon I will try the new bulb again and may even attempt to slightly bend the switch out a little so that it is easier to engage.
Jan 05, 2011 | Sony KDF46E2000 46" Projection HDTV
Removed the bulb with housing from my panasonic pt50lc13 tv but need help on removing bulb from housing
I have replaced my bulb in the housing and it is a tricky process because there are 3 T10m torq screws on the inside of the housing that have to be removed with a very long T10 tork driver as well as 1 on the outside which holds the 2 plastic covers together. 2 screws are located on the same cover which the bulb is located in and the 3rd screw is located on the plastic which has the ancroring screw in. Be very careful not to touch the bulb with bare hands as this will destroy the life of the bulb (always use gloves when handeling the bulb)
Feb 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Need to replace lamp cant figure out how to take out
on the front of tv set there is a panel that you unscrew to get to the lamp then once you get that done you have to go through the back of tv to remove and yes you can buy the bulb by itself but you have to order it or any tv repair place might have one in stock
May 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My hitachi 50v720 bulb blew and the replacement doesn't fit
I have a 50V525E and I have the same problem....My bulb is suppose to be a LM500 and I received a P22 Phillips (And I did check their web site and that is the bulb they recommend), and like you said...The 4 little glass tabs will not allow the bulb to sit flat in the housing.....
I am waiting for the vendor to answer my inquiry...But I recommend to anyone ordering a bulb...Ask if it is Phillips, and if it is...stay away.
Steve
Jan 23, 2009 | Hitachi 50VF820 Projection TV
Bulb Replacement for Sony TV KDF-42WE655
no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
XL-2100U lamp cycles on and off
Hi
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
Sep 10, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
I've got a replacement lamp for a Samsung HLR 5067. The old lamp is a BP610125A. I was told that the new replacemet lamp is a BP96-00826A. The problem is the new Lamp's housing seems too big for my Hd...
I have the same bulb and was told by Replacement Lamps the same thing. No you can not switch the housings. I tried. The bulb is too large and does not fit in the old housing. It is the wrong lamp all together.
Aug 22, 2008 | Televison & Video
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
