Question about Freeplay Energy BayGen AM/FM/SW Radio
I broke the antenna on my BayGen radio. Any ideas on how to get a replacement.
    President:
  • 1,114 Answers
Radio Shack, or any small electronics parts supply house will have one or can get one. Hope this helps.
Posted on Sep 26, 2009
I need relpacement antenna for a pair of radios
  • This radio is a standard FRS handheld. Unfortunately these antennas are not replaceable nor do they make them in an aftermarket aspect. If the antenna is no longer working or broke then the radio[s] need to be replaced. No way around it, sorry,.
  • Hope this helps.
Nov 02, 2011 | Uniden FRS1400 2-Way Radio
Power antenna broke and I need to replace it. How
Buy replacement antenna mast. Remove old one by unscrewing the retaining cap nut. Turn on the radio & let the antenna cable run all the way up while you pull on it to remove it.
Install the new antenna mast by turning the radio 'off' so the spool inside goes back to its beginning while you feed the cable of the new antenna down into the antenna mast hole.
Once the cable is all the way down, reinstall the retaining nut/cap and turn on the radio to allow the spool to run the antenna 'UP.'... cycle the radio ON and then OFF several times allowing the antenna to move all the way up and all the way down.
That's it!
Sep 28, 2009 | 2001 Hyundai Sonata
The antenna base on my Maxon HCB-10C CB Radio got pulled out. Can I fix this?
Not sure what you mean here...
If the antenna is broke, then you should just get a new antenna. If the antenna connector was pulled out of the radio, it is usually fixable.
If the connector is broke off the antenna, it may may be fixable, I would have to see it. If its done wrong, you could hurt the transmit section of the radio.
You should just get a new antenna.
Sep 25, 2009 | Maxon HCB-10C CB Radio
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Antennae broke
Just go to any radio shack they have lots of antennas
Oct 27, 2008 | RCA RCD110 Radio/Cassette/CD Boombox
Original Freeplay windup radio.
Tony,
Can't help you with the aerial. Mine made the same noise when winding down and I fixed that by pouring talcum powder around the windup section. Let it unwind and allow the talcum to go in,,,, and presto.......no more grinding noises.
Carlo
Jul 07, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
Pin in back of receiver broke off
If you can put your hands on another unit for parts, you can open it and replace your damaged pin with one from the unit for parts. It takes a little time and care but you can do it.
Mar 17, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Spring broken?
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
Feb 27, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
Midland handheld CB antenna
The connector that's part of the radio, or part of the antenna broke?
Oct 30, 2007 | Radio Communications
Freeplay Energy BayGen AM/FM/SW Radio Logo
221 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
RudeRude
John In Milford
John In Milford
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
