Question about Olympus Camedia D540 3.2 Megapixel: P-10 Digital Photo Printer
The paper jam light continues to blink when there is no paper jam. This is a new from the box Camedia Digital Photo Printer P-10. (four years old never used). It did try once to print and got a paper jam, but i have cleared the jam and turned it on and off and left it to cool etc etc. I have had the back off and there are no obvious problems.
Light flashes 3 times
Which light? Orange? You probably have a paper jam or an obstruction in your paper feed path:
e.g.
Orange light blinking 3 times
1250/E17
Description:
The front door is closed.
Resolution:
Open the front door to allow prints to exit.
1300/E03
Description:
A paper jam has occurred during printing.
Resolution:
Locate and remove the jammed paper from the printer.Press the button on the device to continue printing.
1303
Description:
A paper jam has occurred in the rear tray.
Resolution:
Remove the jammed paper from the rear tray.
Derived from: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
Apr 14, 2014 | Canon PIXMA iP3500 Printer
Continue to receive E error message
Check control panel lights, if cartridge led's are blinking replace particular cartridge, if paper led's are blinking check any paper jam inside, if no paper found clean paper sensor.
Nov 24, 2011 | HP PSC 1315 All-In-One InkJet Printer
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Hi, My hp k550 is blinking at lights 1 and 4. How can I fix this problem please? Thanks
Issue
The power light and resume light is blinking.
Power light and resume light is blinkingc01576793.gif Solution one: Press the resume button
Load paper in the paper tray and press the resume button (c01219285.bmp ).
Try to print the job. If the issue continues, proceed to the next step.
Solution two: Clear the paper jam
Step one: Clear the jam from the back and top of the product
  1. Remove any paper loaded in the output tray.
  2. Turn off the product.
  3. Push the button on either side of the rear access panel or duplex unit and remove it. Figure 7: Removing the rear access doorc01576794.jpg
  4. Locate any jammed paper inside the product and pull it out towards you.
  5. If there is no jam, push the latch on the top of the duplex and lower its cover. Figure 8: Lower the product coverc01576795.jpg
  6. If the jam is there, carefully remove any jammed paper and close the cover.
  7. Replace the rear access panel or duplex unit.
  8. Open the top cover.
  9. Check for and remove any jammed paper by gently pulling it out.
  10. Make sure that there are no scraps of paper stuck between the rollers.
  11. Close the top cover, turn on the product, and resend the print job.
Try to print the job again. If the issue continues, proceed to the next step.
Step three: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Cause
The product might be out of paper or there might be a paper jam.
Feb 28, 2011 | Office Equipment & Supplies
My HP 610C printer yellow light is blinking after the paper is taken in. The power light is steady. Therafter the yellow light blinks continuosly. Please help.
Follow each of these steps until the problem is resolved:
  • Remove the paper from both paper trays.
  • Press the power button once. Wait a moment for the paper jam to clear.
  • If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  • Remove the rear access door.
  • Remove the paper jam through the opening at the back of the printer.
  • Replace the rear access door.
  • Reload the paper into the paper In tray.
  • Print the document.
Sep 29, 2010 | HP Office Equipment & Supplies
Lights are flashing on printer and it will not print . the voice says there is a problem with the printer. I did the alignment process but the voice keeps saying there is a problem. I took both cartridges...
There 3 light on the printer that able to indicate to user when problem occur. Which is the light u mean here?
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Sep 28, 2009 | Lexmark X2500 All-In-One Printer
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Olympus Camedia D540 3.2 Megapixel: P-10 Digital Photo Printer Logo
43 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
