Question about Amana MVH340 Microwave Oven
BOTH OF THE COOKTOP/NIGHT LIGHT BULBS NEEDED REPLACEMENT. When removing, both bulbs snapped off their base. Used a pair of needle nose pliers to loosen the lamp bases and removed. Replace with two new 40 watt appliance bulbs and the light still does not work. Are thse bulbs controlled by a fuse? Everything else of the MW is working properly.
  • Anonymous Mar 20, 2014
    Went to change cooktop lightbulb and found that the bulb was broken away from the threaded portion where it screws in. Bulb was hanging by a thread which came off in my hand. How do I remove the broken off portion and can I replace with any 40 watt appliance bulb?
  • Amana Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me for more information.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 28, 2009
This is an over the stove microwave. Need help replacing the light bulbs on the bottom of the microwave.
Disconnect the power and get a flat bladed screw driver to remove some of the bulb base away from the socket. Insert long nose pliers into the area created and turn base counterclockwise to remove.
Nov 21, 2015 | Microwave Ovens
Can't remove bulbs over top stove
With microwave unplugged you may have to break the glass bulb then use needle nose pliers to grab the bulb base to twist it out. If you can't get it that way you'll have to order a new socket.
Nov 10, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
Change a JennAir JMV8208aa Microwave light bulb
Inside light
1. Disconnect power to oven.
2. Remove screws located in front on top of microwave securing grille.
2. Remove grille.
3. Remove screws securing bulb holder.
4. Remove light bulb
Cooktop lights
2. Remove lamp cover or remove screws securing bottom plate cover.
3. Disconnect lamps.
If your bulb is stuck or physically broken, it can be a pain. It's sometimes tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
The lamps are available at most grocery stores, hardware stores, home centers, and places like Wal-Mart and Lowe's.
If the unit uses halogen bulbs, do not handle them with bare hands, as oils from the skin make them run hotter and shorten their lives.
Sep 21, 2008 | Jenn-Air JMV8208AAS Microwave Oven
WE have a GE Spacesaver Microwave installed July 2005. I have tried to replace burned out nite lite bulb. Both bulbs broke from socket as I tried to unscrew. Bulb base will not unscrew. How do I get the...
First be sure the oven is unplugged whenever you are removing or installing light bulbs.
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
Once you get new bulbs in, if they don't work, that's circuit board damage which we repair for $39.95 for customers nationwide and you can feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
Aug 01, 2008 | Microwave Ovens
Removing light bulbs - HOW?
First of all, please be sure your oven is unplugged!
If the filament shorts, or if the bulbs are removed or installed without first unplugging the oven, it can cause damage to the controller board reuslitng in lights that don't work or that won't shut off.
But back to your bulb removal problem... They are often tacked in place with hot glue.
If you can heat it up a bit with a hair dryer, it may soften the glue enough that you can unscrew the base with a good pair of needle nose pliers.
It may be helpful to out the tips of the pliers inside the bulb socket, spread the handles apart, then turn while holding the handles out.
Tubular 40-watt bulbs (40T6 1/2 /2), available in supermarkets and hardware stores, may also be used for replacements.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 24, 2008 | Hotpoint RVM1425 Microwave Oven
Broken bulb
From what others have said, it will come out, but you have to use some strong good needle nose pliers to turn the base in the socket.
Jan 12, 2008 | Whirlpool MH2155XP Microwave Oven
Replacing light bulb
Remove the screws on the bottom of the unit and the panel drops. You can then remove one screw on the actual bulb holder and use plyers to spin it out. Make sure you disconnect the power.
Dec 16, 2007 | Microwave Ovens
Bulb replacement
It aint haolgen. This is another GE piece of POO engineering.
Unplug the microwave FIRST.
Now, Make sure your stove top is cold!
There are 6 phillips head screws holding a plate that secures the stove-top light and grease trap filters on the underside of the microwave. Lay on our back on the cooking elements looking at the bottom and remove the screws. The plate should swing down on hinges in the back.
Then remove the "bulb holder" which is held inplace with another phillips head screw. You can see what it looks like: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100389
You should now be able to remove the "screw-in base" of the bulb with your hand or in my case, because I was so tight, I man-handled it with a pair of needle nose pliers.
Now, go find a bulb! good luck.
Nov 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulb replacement
Yes it just unscrews.  Unplug the microwave first!  Then use some needle nose pliers and put them inside the base open the pliers to put pressure on each side of the base.  Now turn the base counterclockwise.  Let me know how it turns out.
Oct 16, 2007 | GE JVM1651 Microwave Oven
Surface lights
I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
Sep 05, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
