Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 can't print anymore
I keep getting this message:
The print spooler was unable to connect to your printer. This can be caused by your printer being turned off (which is not the case), the cable being unplugged (I am using wireless), or being connected to a VPN (don't know what this is), which will block your access to your local network. Your document will print when the printer becomes available. (never does)
I get the same error on my laptop or main computer. Anyone know what this means? It just recently happened. Was working fine before.
Thanks
  • 1 more comment
  • Anonymous Jan 02, 2008
    This happens to us occassionally. It is a difficult problem to solve and not really sure the solution but when it has happened it has been because either the power went out or someone had shut the printer down. I fixed it once by going on to the printer screen of the device and resetting the wep code.This is done by going to option 8 network and then 4, You need to then go onto your admin website for resetting your web key. Then shut the pc's down (main one and any wireless ones) then restarting the PC's. Do NOT shut off the printer.
  • Anonymous Jan 05, 2008
    unable to print from the computer
  • birkdale52 Jan 28, 2008
    I have the same problem not able to print from computers
    Have tried everything I can think of. Have contacted HP tried everything they suggested nothing doing. Dont know what to do now.
    Wont even connect with an ethernet cable.
I think I have solved this, any way it worked for me.
Turned off printer and turned off wireless router made sure no computers are on.
Restarted printer make sure wireless settings are installed in printer then restart router.Once router is up and running switch on computer and you should be able to print.
Hope this works for you.
Posted on Jan 29, 2008
2 Suggested Answers
  • 38 Answers
SOURCE: print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Posted on Nov 07, 2009
Unable to print and make photocopies
when you try to print does it come up with any error message?
or does it get sent to the print spooler and then lost in cyberspace?
or does it get to the printer and then the printer says no?
for the error message follow what it says so if the error is no connection check that the wires are attached. if it comes up with an error code look it up on the HP website.
if it gets lost in cyberspace try reinstalling the printer with an updated driver.
and finally if it says no go to run and type services.msc and scroll down the list till you see print spooler if it says it is stopped start it and try again, if it still doesn't work try updating the firmware
Jan 03, 2014 | HP LASERJET PRO M1132 MFP
HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
May 22, 2009 | HP LaserJet 2200dn Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Display screen stuck on hp invent - buttons don't work
This is apparently a common problem with this model, but HP has not offered any help with it. Mine did it a few weeks ago and I found the solution in another thread on fixya. Follow this link and then open the back of the printer and disconnect the wireless card as described by Maggix. It will kill your wireless capability but let the printer start working again.
http://www.fixya.com/support/t648531-hp_7410_all_in_one
Jan 01, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Won't Scan
OK
PLEASE REINSTALL THE PRINTER DRIVER AGAIN.
Nov 22, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
Error message
My printing stops and I get this error message Error-0x07a74dd6 1959:lib_barracu.
What is the meaning to this and how can I fix the problem?
Mar 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
306 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
