Question about Acer Aspire 5315 Notebook
Acer laptop 5315. While using the laptop it just
Acer laptop 5315. While using the laptop it just went blank. no power lights no nothing
  • j_md333 May 11, 2010
    you should try torning it on agean
  • 39 Answers
This laptop is cleverly designed, it is most probably the daughter board. this is where you connect you ac adapter. the daughter board or power board, eliminate the need for you to replace the whole motherboard when the connector is damaged. all you need to do is replace the power board. if this does not fix the issue, then there is a likely hood that you need to replace the motherboard
but before you attempt the above, first check if the ac adapter is not the problem
Posted on Sep 26, 2009
Factory reset acer aspire 5315 gone wrong
I think you need to reload windows with a operating system disk. Most times the Factory Recovery discs don't work.
Get a windows operating system disk and just reload windows. The disk must match the Certificate of Authentication (COA) sticker on the bottom of her laptop. In other words, don't use a Windows XP Home operating system disk if the COA sticker says Windows XP Professional or you'll never be able to activate windows.
May 06, 2012 | Acer Aspire 5315 Notebook
My acer aspire 5315 wont turn on I press button and it lights up as if gonna come on but screen stays blank and then it powers out its only 1 year old help
Maybe the screen has some problems, or try clicking to the power button for some minutes, or Try charging the laptop, or try to change the laptop's battery.
This is all I know, wish it works :)
Jul 16, 2010 | Acer Aspire 5315 Notebook
The laptop 5315 is not charging , no red glow
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 12, 2010 | Acer Aspire 5315 Notebook
Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
Feb 19, 2010 | Acer Aspire 5315 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 25, 2009 | Acer Aspire 5315 Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
SCREEN GOES BLANK NOTHING COMES UP
on restart press f8 then safemode
do a virus scan
then a disk defrag
have you added anything new or changed the system
please let me know if this helped and don't forget to rate me
thanx
Jan 30, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
151 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
