Question about Kodak EasyShare Thermal Photo Printer
RIGHT SIDE PRINTING ONLY
I HAVE A SIMILAR PROBLEM ONLY MY PRINTER WILL ONLY PRINT THE RIGHT SIDE. I SPOKE TO A TECH ABOUT MY PROBLEM. HE SAID I WOULD HAVE TO MAIL IT IN TO BE FIXED. THE CHARGE WOULD BE $80.00
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Epson Aculaser C1100 Just replaced Black Cartridge still printing with wide black line on right hand side of page
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Mar 30, 2011 | Epson Aculaser C1100 Printer
I have the hp 2640 half the right side of the page good but the left side is fain you can hardly see fade out form right to left side of the page
Most likely your print heads need to be cleaned. To do this go to start, devices and printers, right click on your printer and choose printing preferences, click on the color tab and at the bottom there will be an option that says printer services, click on this and click on clean cartridge. This should be all that you need to do! ;)
Oct 10, 2010 | HP LaserJet 2840 Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Biz hub 250 Pdf printing problem
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
HH
Aug 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Samsung ML 2510
The problem is the heat transfer unit in the printer. The heat unit on the right side is either not heating up at all or not enough to transfer the toner to the paper. If the printer is still on warranty it needs to be repaired by a tech. If the printer is off warranty, it's usually not worth fixing.
Jun 03, 2009 | Samsung ML-2510 Laser Printer
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Kodak EasyShare Thermal Photo Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
