Question about Toshiba 62HMX84 62" Rear Projection HDTV
No picture, starts normally then shuts off. blue light stays on. replaced lamp, and still the same problem. toshiba 62hm196
T.V is going into protection mode, will have a short of some sort.
Posted on Sep 26, 2009
    Brigadier General:
  • 4,090 Answers
If a tv turns off after being turned on It is enambling the safe mode to prevent greater damage. It has probably got a bas chip or sync switch on the power board.
Flickering picture
It is possible it is the lamp or a issue in the power supply of the set.
Jun 13, 2012 | Toshiba 62HM196 62" SD Television
Lamp light blinking
The problem is that your lamp has expired, You need to either get in touch with the brands authorised repair agent and they can order and replace lamp( at a cost) or you can replace the lamp yourself. Also make sure you know how to rest the lamp use hours after replacing the lamp. Good luck.
Nov 20, 2009 | Toshiba 62HM196 62" SD Television
Toshiba 62hm196 just replaced lamp 2 weeks ago and this one is blown to, fan is working fine is it just a bad lamp or could something else be causing failure? When i inserted the replacement it fit...
It could be the ballast. The ballast is what fires the lamp and an over or under voltage to the lamp could cause it to blow prematurely. A clogged fan could also be causing the issue if the lamp is not cooling correctly but you said the fan was fine.
It could had just been an defective lamp, send the lamp back to where you bought it and tell them it was defective. There also should be return instructions that came with the lamp and also warranty information.
Nov 08, 2009 | Toshiba 62HM95 62" DLP HDTV
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
239 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
