Question about Logitech Driving Force Pro (963293) Wheel And Pedals Set
Bake-gas crossfeed I have 2 pro force wheels with the same problem-after 5 min or so of playing the brake will start to apply and get worse until car will not move. Gas will still work and at times working pedals will make better but not for long until game is unplayable. GT3 GT4 games. thanks Rick
  • Anonymous Oct 24, 2008
    My pedal has the same problem. Is there a fix?
  • Anonymous Nov 22, 2008
    PS3 GT5:P using Force GT wheel, I get the same issue. Been driving me nuts. Where the car will not move, acts like its not getting gas even thought the white gas pedal indicator graph is moving. I thought it might be damage simulation. Also car gets stuck on a wall and will not respond to reverse or steering.
  • 3 Answers
The problem is dust inside the pedal potentiometers, just take apart the pedal box, make sure the pedals are facing downward when you remove the bottom cover, otherwise the springs are going to pop out, once inside you will see the inside on the pedals, a couple of springs and two potentiometers (where all the wires connect to) take one of these out carefully and spray the hell out of it with WD40, turning them with your fingers back and forth all the way, put it back in and repeat the process with the other one, make sure they are in the same rotation position when you put them back in and make sure they seat properly before you put the back cover on. this will fix the problem, if problem keeps coming back just take one out and go to your local electronics store and get replacements just make sure you wire them like the originals
Posted on Dec 08, 2008
If you pause the game you can reset the pedals but unpluging them from the main unit then plug them back in, they will then reset and the you will have another 5 minutes of playing until the brake goes hay wire again.
Posted on Apr 20, 2008
Changing pump and bleeding power stearing on a 1983 buick riviera
1. Replace any hydraulic line showing external damage. Rubber hoses more than 4 years old should be replaced. Install new seals for all disconnected fittings (as required) and install an in-line power steering filter. Tighten all hose fittings to OE specifications. 2. Flush the entire power steering system using the vehicle manufacturers recommended fluid. Fill pump reservoir to the proper level.
3. Disable engine to allow cranking without starting. This can be done by unplugging the main power wire (large red one) from your Delco HEI Distributor unit. Block wheels, put transmission in neutral or park and set parking brake, then crank engine 5 to 10 seconds (avoid overheating starter motor).
4. Refill pump reservoir as necessary. Repeat step 3 until level is correct.
5. Enable the engine to allow starting. Start engine and let idle. Slowly turn steering wheel from lock to lock a number of times.
6. Turn engine off and inspect fluid level and condition. Add or remove fluid as necessary. If fluid is foaming, wait one hour then recheck level. Repeat step 5 and 6 until fluid level is correct and shows no sign of air. If the problem persists recheck installation and connections.
1. With engine off, apply and release brake pedal 5 to 10 applications to deplete accumulator reserve pressure. With foot slightly pressing brake pedal, start engine. Pedal should drop and then push back against your foot.
2. With engine running, turn steering wheel until lightly against steering stop. After 5 seconds return wheels to the straight ahead position and turn engine off. Apply and release brake pedal. There should be at least one power assisted brake application. Start engine and allow accumulator to recharge before moving vehicle. 3. Test drive vehicle.
NEVER operate any vehicle until brake and booster systems are functioning properly. Remember, your vehicle is only as good as it's braking system. Brakes are the singlemost important component on any motorized vehicle.
Nov 06, 2016 | Buick Cars & Trucks
How to adjust parking brake on 1993 chevy lumina ?
  • Adjustments
  1. Apply service brake pedal three times with a force of approximately 175 lbs.
  2. Fully apply and release parking brake three times. Full application may require two pedal strokes.
  3. Raise and support vehicle, then mark relationship between wheel and axle flange.
  4. Check parking brake pedal assembly for full release as follows:
    1. Turn ignition switch to On position.
    2. If ``Brake\'\' lamp is illuminated, operate manual brake release and pull downward on front parking brake cable to remove slack from pedal assembly.
  1. Remove rear wheel and tire assemblies, then install two lug nuts to retain each rotor assembly.
  2. If two parking brake levers on both calipers are not against lever stops on caliper housings, check for binding in rear cables and/or loosen cables at adjuster until both left and right levers are against their stops.
  3. Tighten parking brake cable at adjuster until either the left or right lever begins to move off the stop, then loosen adjustment until lever moves back barely touching stop.
  4. Operate parking brake several times to check adjustments. A firm pedal feel should be obtained by pumping pedal two full strokes and rear wheels should not rotate forward when parking brake is fully applied.
  5. Install wheel and tire assemblies, aligning marks made in step 3.
Sep 06, 2014 | Cars & Trucks
Transmission
It sounds to me like you have a issue with your linkage . Get Under the car make sure you chock the wheels and have someone get in vehicle and at temped to shift the gears . You could have ran over something that is causing the linkage to be stuck . If that don't work I would suggest you get a Transmission Mechanic to look at it . Don't force it because you could bend the linkage and your problem will just get worse.
Jan 29, 2014 | Oldsmobile Aurora Cars & Trucks
Engine does not start abs light flashes
ABS - Anti-Lock Braking System And EBD -Electronic Brake-force Distribution In Plain English Posted by: Rohit Khurana March 1, 2010 in Automobile Technology
AdvertisementCarBlogIndia Technology Articles , today I will talk of one of the most talked about safety feature called the ABS And EBD. Again I will try to keep the language simple and human understandable (which non-engineers can also make some sense of), pun intended.
What Is ABS ? Anti-Lock braking System system or ABS is a safety system which prevents the wheels on a moving vehicle from locking up(or cease while rotating) while braking. ABS offers improved vehicle control over dry and especially slippery surfaces by reducing the braking distance but it can also increase the braking distance in case of loose surfaces like snow, gravel etc. Ever since the invention of ABS, it has been evolving and the recent systems not only prevent wheel locking but also electronically control the front-to-rear brake bias, which we know as Electronic brake force system, Traction control system, Emergency brake assist or Electronic stability control.
Working Of ABS
Advertisement
When brakes are applied under heavy loads, the braking pressure becomes high resulting in heavy braking or in other words locking up of wheels. The ABS overcomes this by monitoring the wheel speed and releases pressure on each wheel brake lines in the form of rapid pulses switching between different brake lines. which prevent locking-up.
Preventing lock-up under heavy braking helps the driver in maintaining control over the vehicle. In modern ABS an individual brake line is provided for each of the four wheel enabling different braking pressures for different road surfaces of the wheels.
What Is EBD ? Electronic brake- force distribution system also called as Electronic brake-force limitation is an automobile brake technology that automatically varies the amount of force applied to each of a vehicle's brakes, based on road conditions, speed, loading, etc.
EBD system is always coupled with anti-lock brake-force system. The most important function of EBD is to maintain vehicular control with variation in braking pressure applied to each wheel in order to maximize stopping power. Generally most of the weight of all vehicles is carried by the front end so the EBD ensures less braking pressure at the rear end to avoid skidding. But in some EBD's the distribution of braking pressure at the rear end is more initially when the brakes are applied before the effects of weight transfer comes into play.
Working of EBD system An EBD is a subsystem of the abs and its function is to control the effective adhesion utilization by the rear wheels. this definition has been given by SAE in its technical paper no. #920646.
Advertisement
The Antilock brake force system releases pressure in different brake lines at the time of heavy braking to prevent locking-up. The action comes in the form of releasing pressure from the braking circuit when it detects extreme and rapid deceleration in any of the four wheels in order to make sure that the driver maintains control over the steering during panic or emergency braking. For example if the wheels of a vehicle are on snow as well as asphalt then in case of emergency braking the ABS will monitor the speeds and eventually the EBD system will release less pressure for wheels on snow and more pressure for wheels on asphalt to prevent wheel lock-up
Sep 25, 2013 | BMW Motorcycles
Why is the emergency brake cable very loose
Probabily needs adjustment---
  1. Remove the screw covers, screws and parking brake trim cover.
  2. Turn the adjuster as needed to attain the proper adjustment.
Make sure the brakes do not drag when the parking brake lever is released.
  1. Reinstall the trim cover.
  2. Depress the pedal 2 notches.
  3. Tighten the adjusting nut at the pedal assembly until the rear brakes just begin to drag when rotated.
  4. Release the parking brake lever and check that the wheels do not drag when turned. The parking brake should engage in 3-5 notches when a force of 66 lbs. (294 Nm) is applied to the parking brake pedal.
  5. Lower the vehicle
Nov 16, 2011 | 1998 Honda Civic
1998 honda civic lx drivers side rear emergency brake cable spring is very loose
I have a ford explorer 2004 /2005, and is given this heavy noise at the front wheel while the there is an increase in speed,what are the signs of a hub bearing, because i am suspecting the front hub...
The best way to check is to lift the corner of the vehicle clear f the ground and then with a trolley jack lift the lower wishbone to put pressure on the suspension spring. This removes any force on the ball joints and bearings associated with the wheel hub. Grab the wheel 9 o'clock and 3 o'clock and rock the wheel from side to side to side. If there is any slack or minor play you will feel it first and possible see and hear it. Now take the wheel in the 6 o'clock and noon positions and and again check for play. Now remove the wheel and apply the rocking motions again to the naked hub. You should be able to see any fault with the steering knuckle, the wishbone control arm ball joints and bushes along with any play in the hub bearing. The bearing should run smooth and you should neither feel or hear any roughness from the bearing. If there is a lot of play detected try this: Remove the locking pin on the main bearing nut and then tighten the nut until free rotation of the hub begins to become stiff. Now loosen the main nut by two flats only and refit the locking pin. Refit the wheel. When driving, a worn bearing is indicated by a persistent whining growl. On front wheels the noise often gets worse during a turn as the weight of the vehicle is transferred. While the wheel is off check the condition of the brake rotor ensuring there are no warps or cracks. A damaged rotor is indicated often by a thump thump sound front he wheel and this is accentuated and felt through the brake pedal when the brakes are applied
Aug 24, 2010 | Ford Explorer Cars & Trucks
Shake in steering wheel
Sounds like your brake rotors.You dont have to feel it in the pedal to get a shake in the wheel.
Nov 26, 2008 | 2004 GMC Savana
My brakes are locking up on all four wheels on my 04 sentra.
Your brake light switch is adjusted in all the way and is pressing on the brake pedal. This causes the brake to be slightly applied. As you drive the vehicle the brake fluid heats up and expands, the brakes will apply more and more until you see the smoke. Bottom line: your brakes are always applied at the master cylinder because something(usually the brake light switch) is out of adjustment.
Nov 12, 2008 | 2000 Nissan Sentra
Brake-gas crossdeed
http://merc460racing.com/GT/repairing_logitech_driving_force.htm
Dec 18, 2007 | Logitech Driving Force Pro (963293) Wheel...
Logitech Driving Force Pro (963293) Wheel And Pedals Set Logo
293 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
