Question about Whirlpool GEW9250 Electric Dryer
My dryer won'y blow hot air
After checking all the heating components resistance (Thermal Cut-Off, Heater Element, High Limit Thermostat, Thermal Fuse, and Thermistor) with an Ohm meter, I am still having a problem with the dryer not heating properly. I have checked the exaust temp and it will not get above 120 degree which is the range between Extra Low and Low. From the Tech Sheet I found attached inside the dryer it should be heating closer to 150 degrees when the temp setting is on high. Have any suggestions.
  • bpaul Dec 18, 2007
    Bob,
    I removed the heating element and noticed that a portion had shorted out and turned Black. So I have order a replacement heating element.
Bob, I did not lie, I just checked the heating element orginally with an Olm meter while the element was still installed in the dryer. After more reading on the internet and testing I decide to remove the heating element and noticed it had the short.
Posted on Dec 18, 2007
  • 833 Answers
Bpaul...first, check to see if you have full power to the unit. These units run on 220 volts which involves two breakers linked together...my guess is one popped and you're running on 110. You'll get some functions but not full heat. Turn the breakers off and back on. Not it? Then check for lint in the piping which is causing a false reading on your temp sensor.
  • Robert Hirst Dec 18, 2007
    b...you lied about the heating elements! Glad you got it.
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    My whirlpool leb 6000 pqo will not heat
    check heating coils, high limit, temp selector switch.
    Apr 05, 2011 | Whirlpool Dryers
    My dryer does not get hot anymore
    The thermal cut-off located on the heater housing is likely blown. It blows if there's an issue with clogged ducts and/or faulty high-limit thermostat. These components including the cycling thermostat on the blower housing are wired in series with the heating element and power to the heating element is terminated if one of them, usually the thermal cut-off, cuts or blows open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
    Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
    Feb 28, 2011 | Kenmore 700 7973 Dryer
    Where would the fuse be and how hard to get to, is it in the upper unit? From behind? or lower unit? Running but no heat.
    The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
    Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
    Dryers with lint filter on the front.
    Dryers with lint filter on the top.
    Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
    The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
    Feb 01, 2011 | Dryers
    Dryer quit heating no power to element what is wrong?
    The problem is most likely the thermal cut-off and the high-limit thermostat. The thermal cut-off blows when the high-limit thermostat fails and since these parts are wired in series with the heating element, power to the heating element is therefore terminated. Check the continuity of the thermal cut-off and if it reads open, replace it along with the high-limit thermostat.
    You can bypass the thermal cut-off and the high-limit thermostat for troubleshooting purposes. Join together the wires of each part and insulate it properly then reconnect power. The two components indeed need to be replaced if the dryer heats up. If not and still no power to the heating element, check the continuity of the heating circuit. Check the continuity/resistance of the heating element if there's power to its terminals but doesn't heat. Replace the heating element if it reads open.
    Let us know if you need further advice. Just indicate the exact model number of the dryer for accurate troubleshooting tips.
    Jan 23, 2011 | Kenmore 700 6972 Dryer
    Model LEQ9508PW1. It has stopped getting hot. Just stopped putting out any heat. I assume that it is probably the heating element that has gone out. Is there anything else I should check first before...
    Check first the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
    Also bypass the cycling thermostat if the dryer still doesn't heat up with the thermal cut-off (cut-out) and the high-limit thermostat both bypassed. If the dryer still doesn't heat up, take the heating element out and inspect it for damage. Replace the heating element if damaged.
    Jan 18, 2011 | Whirlpool Dryers
    Dryers tumbles but there is no heat
    Dec 31, 2010 | Kenmore 600 6965 Electric Dryer
    My kenmore dryer is blowing only cold air. What is wroge? We already checked the heating element and timer...???? This dryer is only 4 years old.
    The heating circuit is composed not only by the heating element and the timer but also with a high-limit thermostat, a thermal cut-off, and a cycling thermostat. The high-limit thermostat and the thermal cut-off are both mounted on the heater housing to monitor and regulate the heater temperature while the cycling thermostat is mounted on the blower housing to monitor and regulate the temperature of the exhaust air.
    All of these components are wired in series and a failure in any of them results in the dryer not heating. The proper troubleshooting is by checking the continuity of each of these components with a volt-ohmmeter and replacing the ones found without continuity (open).
    A continuity check can also be done by bypassing each of the three components, never the heating element, and then starting the dryer. The dryer should heat, otherwise the problem is somewhere in the timer, the heating element, or the centrifugal switch within the motor. When the dryer heats up, unplug it then un-bypass one of the bypassed components and start the dryer. If the dryer stops heating then you have found the failed component; replace it. If the dryer does not stop heating, do the same to the remaining components until you find the failed one. Just make sure the dryer is unplugged before touching the components.
    Replace both the high-limit thermostat and the thermal cut-off if any of them has failed. Indicate the exact model number of the dryer if you need further or more specific advice.
    Jun 12, 2010 | Kenmore 63942 Dryer
    How do you replace the heat element on a whirlpool LER8648 dryer?
    Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
    All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
    May 28, 2010 | Whirlpool Dryers
    My dryer has no heat
    If the model number you posted this question under is correct, your heating circuits are comprised of the following components:
    1. Heating Element
    2. Thermal Cut-Out
    3. Hi-Limit Thermostat
    4. Internal Bias Thermostat
    5. Thermal Fuse
    You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
    As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
    The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
    You can refer to the following parts illustration for assistance:
    http://pcappliancerepair.com/model-display.php
    The components are listed as follows:
    Heating Element (Item 17)
    Thermal Cut-Out (Item 6)
    Hi-Limit Thermostat (Item 15)
    Internal-Bias Thermostat (Item 20)
    Thermal Fuse (Item 19)
    If you need assistance on how to troubleshoot a dryer, you can refer to this link:
    http://www.fixya.com/support/r3574266-thorough_dryer_advice
    The MOST common causes of heat related problems: 1. Blown Thermal Cut-Out. 2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers. 3. Bad power cord, causing 1/2 the input voltage to be missing. 4. Blown heating element. Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful. NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
    Apr 02, 2010 | Whirlpool LER4634J Electric Dryer
    Whirlpool GEW9250 Electric Dryer Logo
    141 people viewed this question
    Top Whirlpool Dryers Experts
    Sal De
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
