Question about Sharp R-1470 Microwave Oven
Oven stopped working. No lights, no control panel. nothing
How can I tell if there is anything to salvage on my Sharp $1470. It quit working and shows no sign of life??
  • annsan Dec 21, 2007
    It is none of those things. No life no response. Think it must go.
  • Sharp Master
  • 9,098 Answers
It should be worth fixing. A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number (R-1470) here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
  • William Miller
    William Miller Dec 21, 2007
    If you checked all that, you probably need circuit board repair.
    We do these repairs nationwide on a regular basis for $39.95, and parts, if needed, would run $15 more.
    Our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
    Feel free to contact me directly if you'd like us to take care of it for you.
    Thanks.
Sharp microwave model R-1406 control panel has no light. unit works but you can't tell anything as the led is blank.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 18, 2011 | Sharp R-1406 Microwave Oven
I was cooking mac and cheese and it made a loud noise and just quit working nothing shows up checked breaker and it was fine so was outlet. Sharp R 1470
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Mar 19, 2011 | Sharp R-1470 Microwave Oven
I left a pot of water boiling, causing lots of condensation on the microwave. Unfortnately, another house mate then tried using the R-1470 when smoke started coming out of it. Smells like electronics...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 01, 2011 | Sharp R-1470 Microwave Oven
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
Microwave just stopped working
  • Internal fuse may have opened
  • Door interlock may have failed
  • Magnetron may have failed
  • Control panel may have failed
Jun 19, 2017 | Sharp R-1492 Microwave Oven
Unable to get the touch bottom to work
Quite often on the compact models, the solution is to pull the control panel assembly off, remove the circuit board and clean the surfaces shown in the photo with high-grade alcohol.
That would include the back of the LCD glass and both sides of the rubber strip.
Jan 04, 2009 | Sharp R-1480 Microwave Oven
Sharp microwave quit working
Obviously there was a serious short circuit in this unit which is not normally serviceable by anyone but a factory technician. Since this would not be cost effective, I suggest you replace the oven. New ovens are quite reasonable and have many great features.
Ray
Nov 23, 2008 | Sharp R-1490 Microwave Oven
Sharp 1470 over-the-range microwave - no power on panel
Did you unplug any wires when you took it apart?
Otherwise, I would think one or more of the connectors got unplugged when you removed the control panel.
Another thing that can happen on these models is a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under thebottom edge of the switch. It's usually the top door switch.
You can find the wiring diagram at our site here.
After you look into this, if you still need help, please write back with more details.
Oct 12, 2008 | Sharp R-1610 Microwave Oven
Fan button
Take out the screws holding the sheet metal case on.
Jul 23, 2008 | Sharp R-1470 Microwave Oven
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Microwave Ovens Logo
226 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
