Question about Panasonic PT-47WX42 47" Rear Projection Television
Woodgrain effect lines on picture
Took to repair shop, tech said after two days of troubleshooting, he took signal board out of 2nd TV and put in mine, and the picture was great. Claims components cannot be replaced on the signal board and will contact Panasonic for price of new signal board on Monday. Also said there is a place in Ohio that rebuilds Panasonic boards which may be cheaper. Any comments or sources of signal boards?
  • Nimbi63 Mar 29, 2008
    "This site" turns out to be Slinteriors' site. He shipped me a dead board in high-static bubble wrap.
    On my original board, I found if I used component cooler spray on the front convergence chip, the picture would look good for a second or two then go back to the lines across the screen. I pulled the signal board and resoldered the convergence chips, and the lines across the screen are consistant now (before, they started far apart, and got closer and closer as the set warms up. When prob first started, after five minutes warmup the picture was good.)
    I ordered new convergence chips and changed both, The picture is slightly better, still has lines, but after 30 to 40 minutes, the set shuts off with the three blinks of the front panel red light, indicating convergence circuit problems. Should I replace the resistors, or ?? By the way, after resoldering the convergence chips the first time, the circuit cooler spray had no effect on the picture.
  • Panasonic Master
  • 8,617 Answers
Dont know if youre still looking for a signal board or not but this site has one. I hae used this site numerous times their products are great and prices cheap.
Posted on Feb 22, 2008
  • Sonny Berry
    Sonny Berry Mar 29, 2008
    Return The board and your money will promptly be refunded. One of the new guys in the wharehouse used the wrap that is for screen assemblies on your board by mistake, but as I told you earlier just return the board your money will be refunded and we will rebuild our board. We have helped literally hundreds of people with our patys and services and we would like to honor our committment to you as well.
Fix lcd tv
You need to dertermine if the power board failing charred the connectors, or if a differeb=nt component failed which charred the connectors and took out the power board. This will require component level testing. i suggest taking it in to the repair shop.
However, i would price shop a comparable replacement TV before fixing a 4 year old Insignia. it may be more cost effective to just replace it.
Jan 29, 2015 | Insignia 46 Class LCD 1080p 60Hz HDTV
I have a problem that appears to be related only to my coaxial cable input. I periodically get static, white lines across the screen or a "no signal" error message. Pixilation does not occur. Initially it...
I think your problem is in the tuner, a metal box located near the antenna input. This tuner can be removed and serviced. Sometimes the tuner DC supply line is unstable due to a filter capacitor or zener diode generally rated 33V (most common) and should be the first step in troubleshooting process.
Sep 27, 2013 | Sony KV-36XBR450 36" TV
Static & Picture Loss via Coaxial Cable Input Only on Sony FD Trinitron WEGA XV-36XBR450
The problem may be in the tuner or associated circuit. Firt check the DC supply line to the tuner. This circuit has a limiting resistor (15K 3W) and a 33V zener diode. If these are OK the tuner is faulty and should be removed (sometimes it comes on a separated board attached to the main board) and serviced.
Sep 27, 2013 | Televison & Video
We have a toshiba projection tv 50H72. we are getting picture distortions of lines verticle & horizontal. convergence has been rest, the only way to get rid of the squiggly lines is to turn tv off...
There is a common problem with this particular model that involves what is known as the"Hypermodle" this is a cuircit board that controls signal processing. The symptoms you describe sounds similar to this problem. This board has 11 very small parts call capacitors,that go faulty over time and get worse with more time. Ideally replaceing this board was the right thing to do in the past however since this was a common occurance the boards quickly became in short supply. Toshiba issued a Service bulliteen to shops on how to repair them. I repaired 2 of them a month at the shop. Now this is a repair that only the most experience tech should attempt. very small parts and easy to damage if not done right. Our shop generally charged around 250 to do this repair. most of the cost was in labor. but always ask if they have done this repair before.
May 29, 2011 | Toshiba 50H72 50" Rear Projection...
I have 60 inch zenith inteq projection TV no picture or sound it powers up fine took it to a repair shop tech guy said that a whole board need to be replaced but the board is a discontinued item said it...
May be you went to the wrong place, find another repair shop where they work that brand and type of tv. Doubtless, some parts are discontinued, but they will take parts of another equipment that are dismantled. Good luck.
Oct 06, 2010 | Zenith R60V26 60" Rear Projection...
I hired a TV repair guy who came in took my board to replace the chips, took him two months to get the chips(so he said) then showed back up with it and it didnt fix the issue. Then left again with the...
it would be better to reset it to factory settings first and then configure the settings the way you want it afterwards... do you know that guy? is he even working for a known repair shop in your area? he might not be a certified repair guy...
Nov 08, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Convergence problem ,Help Please
Something is not right here. Is there any possibility that you can get the circuit designation (Rxxx) of the resistors that were "incorrect"? I am not aware of anything like this that can cause the "memory to be erased". The only memory in that area would be the factory convergence settings which can be modified from the service menu. Please try to supply the resistor IDs and I'll check on this.
Feb 13, 2009 | Panasonic PT-51HX41 51" Rear Projection...
53 inch rear projection tv bowed piture
THis set is notorus..bad to converge at the shop seting the convergence takes up alot of my time... you may have to get a technician to converge in factory or service model.. this is something a non tech should not due "you can mess it up good" there may be a convergence amplifer board problem too. suggest getting a tech to chech it out. IF you can converge at all is a good sign that it might just be adjustment. average repair for this is 100 to 200
May 25, 2008 | RCA HD52W59 HDTV Projection Television
Vertical Color Lines with Sound
well I recently took my tv to a tv repair shop and they told me i had to replace the Y board and a Driver board. All in all it set me back $550.00
Aug 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Toshiba 50H50: No picture or sound, red light blinks
On alot of these Toshiba TV sets, there is a fuse called F860 that will blow and the light will flash because of bad solder connections on C 810, and C 809, on the negitave terminal. I have seen many of these boards condemed by non-authorized Toshiba repair shops. Good Luck
Jun 04, 2007 | Toshiba TP50H50 50" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
