Question about Sony KP-51WS500 51" Rear Projection Television
Picture blurred The picture blurred one day suddenly. Pressed Flash Focus buttob and still no improvement. Wonder if I should replaced the Pico Fuses?
  • kevinwu Dec 30, 2007
    CTR1800, I appreciate your reply to my problem. I do get a picture. It seems the red and green are out of alignment. Wonder if you can tell me which board is the convergence IC board? I contacted Sony Tech Support and did not get any help on this. Thanks a lot.
  • Moto410 Jan 04, 2008
    I am having a problem like this. The red and green seem to out of line a bit, and fine print is hard to read. I could really use some help, thanks Josh F.
  • 4,402 Answers
Do you have a picture?
Sounds like a defective convergence IC
Posted on Dec 20, 2007
  • Cary Farah
    Cary Farah Dec 31, 2007
    you should look for IC with the numbers like stk392-???
    most common is stk392-110 replace both ic they will be attached to
    two big heak sinks might be board G, also check the 1watt resisters close by they are small resistance like 3.9 ohms should be 6 of them.
Our TV model is KLV S Series. for few days the pictures were blurred. then suddenly it was all right. now again it is blurred, pictures are like ghost/negative.two three times my son has throne the remote...
Your television have problem in focus appearance.The picture have out of focus that why the picture is blurred.The problem is in the CRT socket of you TV it is connected to the tube,the white crt socket with 9 terminal.So you need to replace the CRT socket o make the picture good.It can be replace by using soldering iron and soldering pump.So you better call a authorized repair technician to do the repair.
Jul 09, 2011 | Sony Televison & Video
My sony hdtv the picture is like a3d effect with red tint flash focus will not work the crosses wont line up any solution or is tv shot?
Replace your Convergence ICs they are Big Black ICs and will have part number on them,
STK392-110. You also need to check the pico fuses in front and back of ICs they will look like resistors Green or Yellow but are fuses 5amps-7amp pico fuses.
Mats Electronics has ICs 1-800-628-1118
Jul 04, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I was watching my HCL4715W TV and the picture
It sounds like one of the convergence Ic chips is bad---you will need to locate and replace both of them and look for any damaged parts around them; there usually are two pico fuses in this area, one for each IC. The fuses do not look like glass fuses--they usually are green or orange in color and will have the amperage marked on them and on the top of the circuit board.
Aug 09, 2009 | Samsung HCL4715W 47" Rear Projection...
Double and triple picture
replace the two STK392-560 convergence ICs they are located on the two large aluminum haet sinks on the DBoard also check the yellow pico fuses near the ICs
Jun 24, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Mitsubishi WS-55511 Convergence problem ? Unable to adjust. Picture is blurred with green shadows around images on screen
Convergence ICs and the two pico fuses need replacement. You can get replacements at the following link with instructions.
Nov 23, 2008 | Televison & Video
Convergence problem
replace the convergance ic chip on the board below the crt of whtever color is not working
Aug 29, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Unable to resolve concave issues
I am also having the same problem. I tried to replace ICs but no luck. I am also looking for service manual in case if some one can give it to me.
Jun 24, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Jun 04, 2007 | Hitachi 46F510 46" Projection HDTV
Sony KP-51WS500 51" Rear Projection Television Logo
57 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
