Question about Dual Electronics XDM7510 CD Player
Dual xdm7510 wont slide down to show both face plates
  • 54 Answers
One of the rods is probly bent it happened to me
Posted on Sep 27, 2009
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
Face stuck wont open
press the small reset button i currently have the same issue and resetting it dont work for me
Mar 02, 2013 | Dual XDMR7710 CD Player
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
Where can i plug in my ipod?
XDM7510 CD Player This dual model radio it comes w/ a Aux, wire plug where it need to be connect it from back of stereo first.
Jan 04, 2010 | Dual Electronics XDM7510 CD Player
Xdm7510 will not accept any disc
try unhooking the battery for a couple minutes then hooking it back up
Sep 25, 2009 | Dual Electronics XDM7510 CD Player
I have a Dual XDM7510 and i can't figer out how to get the face plate off of it
Hello sneary_08,
The front panel was semi-permanently attached during
assembly. In order to be removable, the installer is required to follow specific procedures contained in separate instructions. If the installer did not perform the procedures, the front panel will not be removable.
If the procedure was followed during initial installation, then you can remove the front panel as follows:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
center underside and pull front panel down and away from
unit to remove. To install, insert left side first, then push
right side to secure.
Hope this helps.
Jun 01, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
Face plate removeal
Hello capthowdy148,
Here's the removal/installation procedure:
1) With the unit off, press OPEN to allow the front panel to slide
down.
2) Gently squeeze the release tab located on the bottom center underside and pull front panel down and away from unit to remove.
3) To install, insert left side first, then push right side to secure.
Hope this helps. If it does, please rate as "FixYa.
May 05, 2009 | Car Audio & Video
My Dual XDM7510 display quit working and I can't find out what is wrong. Everything else on the XDM7510 works. Help me please. It was working when I went in the store came back out and no display.
try checking the illumination light on the back of the radio if that doesnt work then try looking at the red ignitionswitch wire and make sure it is connected to the 12vt constant (the yellow wire)
Mar 10, 2009 | Dual Car Audio & Video
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
DUAL XD7500 CD PLAYER PROBLEM
This is what the manual says:
center underside and pull faceplate down and away from unit
to remove. To install, insert left side faceplate first, then push
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Dual Electronics XDM7510 CD Player Logo
469 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
