Question about Yamaha HTR-6030 Receiver
Setting up DVR, Receiver & VCR w/out cable box
I don't have a cable box and need to set up the receiver w/a DVD recorder, VCR and television. How do I do this?
  • 1 more comment
  • ursulattu91 Sep 26, 2009
    Okay, that mostly makes sense. But how do I choose which channel I want to record on the DVDR? Right now the only options are IN1 and IN2. (My last DVDR which died, had a tuner but new one is cost prohibitive...)
    President:
  • Yamaha Master
  • 1,114 Answers
For TV audio thru the receiver, you will need to run an optical cable or RCA analog audio cable from the "Audio Output" or "Monitor Output" on the back of the TV to the CBL/Sat input on the Yamaha. The VCR goes to Video 1 on the receiver and the DVDR will go to DVR/VCR2 on the receiver. If you want to pass Video thru the Yamaha to the TV, use the "Monitor Output" on the Yamaha if it's at least "Component Video" if not, connect your video sources directly to the TV and audio to the Yamaha. Hope this helps. If you need further assistance with this, post a comment and I will help you further.
Posted on Sep 26, 2009
How to record to vcr player/recorde from dish 625 dvr
Hi, Mari!
You can definitely use a VCR with your DISH 625 receiver. To set this up you would need to connect your VCR between your receiver and the TV.
The easiest way would be to run RCA cables from the TV Out to the VCR's TV input. From there, all you would have to do is run cables from the VCR's Out to the TV. Make sure the VCR and receiver are powered on and change to the input on the TV based on where the cables are plugged in on the TV.
If you have any questions let me know!
Tommy Faust
DISH Internet Response Team
Jan 18, 2012 | DISH Network DVR-625 DTV Receiver /...
Snowy screen when I play a DVD
hi!!!!
try to change the cable!!!
may that helpS :)
Sep 27, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
How to use the video source to watch a movie when i have time warner cable service
are you talking about VCR / DVD or DVR source. for VCR or DVD your connection shall be for VCR, cable out from the TW box to VCR in and VCR out to TV (VCR ch selector and TV must be set to ch 3)......... DVD connection out from DVD to TV's yellow/white/red (digital in on TV), to view dvd using remote change source to the digital source (av1 or av2)... for the DVR you must call TW to make sure your box is set up to record and view....
May 07, 2011 | Televison & Video
Connect a Dish VIP622 to a DVD/VCR
Hi piautewith the VIP622 receiver connecting to your DVD/VCR player you will need theinput/output jacks. To setup recordings to your VCR/DVD player, you will want torun from receiver output to VCR/DVD input and from VCR/DVD output to TV input. Thefan on the VIP622 receiver is just like the fan in a computer tower. Even ifthe receiver is off the fan will still run to keep unit the right temperature foryour DVR receiver. MikeHouston of DISH Network
Oct 18, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Trying to dub from dvr to vhs vcr
Is L2 for composite video (yellow) or S-Video? Try watching a video on L2 with the composite video plugged into the back of your TV, if it works, then do the same with the DVR, if that works, then run the DVR composite video into a receiver, then the L2 from the VCR to the video out on your receiver. It's possible that the VCR won't record anything that isn't an applified signal. That's what the receiver does.
Oct 01, 2009 | Sony RDR-VX555
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
60hz hum
I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Recording
Coax out from box into cable in on VCR. Coax out from VCR to Cable in on TV. Set TV and VCR to ch 3. Put in blank tape. Start show on DVR and hit record on VCR. Hope that works for you.
Feb 07, 2008 | Arris DCT6200 DTV Receiver
Setup configuration
Have you tried to? I would need to see a wiring block. unit to unit, labeled at each unit including the monitor. I'll bet you can do what you seek to acheive..Give me more info, I'll show you how to do it.Just a list of makes,models,serial #s. If you have all this in PDF files, shoot 'em to me.I'll draw thr lines for you.
Dec 30, 2007 | JVC RX-D301S Receiver
Yamaha HTR-6030 Receiver Logo
172 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
