Question about AT&T Merlin BIS 10 Phone
2 and sometimes 3 lines don't work \r\nIts a 14
2 and sometimes 3 lines don't work Its a 14 button merlin system with one intercome line
and 8 active lines. the system is over 30 yrs old and has worked very well the entire time The lines that don't work change by the minute. one inoperative line has a light buzz the other dead lines have no sound at all
  • 615 Answers
This is wiring issue and not the systems…check all connections between the phones and the wires, and see if you can get one working cable and use it on a place that does not work and see if it is wire or not…I am sure you have one unit with bad wire or connector that causing the problem as you stated it comes and go.
Please let me know how this worked for you and please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
Posted on Sep 26, 2009
We have one incoming line that we don't want to ring. How do we program the Avaya System to stop ringing when a call comes in on that line?
At ext 10 or 11
press feature 00
LEFT intercom
LEFT intercom
Right intercom
enter extension number to change ringing on
the line buttons will light up if you touch the line it will change the flashing and the ring style.
Once done, press feature 00
Repeat for all phones.
Aug 03, 2011 | Avaya 700340193 Corded Phone
BIS-10 Phone - How to change default line
If you have a "squared" system (each line assigned to a different button), just press a different line button. To change the order of the lines, slide the "T/P" switch to "P" and press the line buttons in the order you want to use them (ie: Line 4, Line 3, Line 2, Line 1).
If your lines are "pooled" you just get the next available line from the pool - no choosing which line you get.
Hope this helps.
Jun 21, 2010 | AT&T Merlin BIS 10 Phone
What is the code to program a Merlin BIS-10 to have only (1) incoming line. I have a 10 button phone and it thinks there are (5) incoming lines?
Enter admin mode:
Slide switch on left (T/P) down to the "P" position.
press the intercom button above TRANSFER
dial the 2 digit extension number you want to modify
Touch the buttons to add/remove the lines.
Green light on means line is active
Green light off means line is not active
Mar 24, 2010 | Avaya Merlin BIS 10 Corded Phone...
My church has an older AT&T Merlin 5 button 8 pin 2 line phone syatem with 4 phones. Need to upgrade the equipment with modern feathers but need to stay with the 8 pin wiring. Can you recommend new...
The Avaya Partner line was one of the branches that AT&T took in phasing out the merlin system. It's been out for at least 20 years and is now up to the ACS with a version number of 8.0 (its not going away anytime soon).Although it doesn't use all 8 pair to activate a set (it uses 4) it still uses an 8 conductor interface on the cards so changing over to it should be fairly simple.
Feb 12, 2010 | AT&T Merlin BIS 10 Phone
Divice goes to intercom not a outside line
just dial 9.
If this is more of an issue of auto line select, we need to know the model of the phone system. Merlin 820? 410? 1030? 3070?
Sep 29, 2009 | Avaya AT&T Merlin Basic Telephone & Modem...
Lines 1 & 3 won't break dialtone on Merlin 410
Unfortunately no. The merlin 410 was an early phone system that didn't have much in the way of programming.
Sep 10, 2009 | AT&T Merlin BIS 10 Phone
Intercom doesn't make beeping sound only flashes Merlin phone sy
Depending on the type of merlin system you have, you should be able to turn the ringers on by moving the switch on the left side of the phone marked T . P to the "p" position. All the lights should light and the set should ring every couple of seconds. Press the line you want to ring and enter *37, repeat for all lines you want to ring. If you want all lines to ring , press any line button and enter *347, slide the T . P switch back to the center "." position.
Hope that helps
Mar 27, 2009 | Inter-Tel Axxess Corded Phone
Unable to use conference button
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
    1. Make or answer the first call.
    2. Put the first call on hold.
    3. Make or answer the second call.
    4. After the second call is connected, press [Feature] [3].
    5. Press the line or intercom button of the first held call.
    6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Mar 11, 2009 | Nortel Meridian M7208 Corded Phone
The following is from here.
IF you have a Lenend or Magix system. IF SO, you will have a VERY LARGE display phone, ususally at the receptionist station. It will be either a MLX20L or a 4424LD+. If so....
Changing the time on a Avaya Merlin Magix system is accomplished from the system programming console. The date is change separately from the time.
Changing the date:
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Date
6. Enter the date as: mmddyy where mm = month, dd = day, yy = year
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
Changing the time:
1. Press Menu
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
Aug 27, 2008 | Avaya MLX 5D Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
AT&T Merlin BIS 10 Phone Logo
26 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
