Question about Cameras
Sb600 compatibilily with d80 how simple? advise settings for portraits
  • 685 Answers
Leave the flash in ttl, with the backlight setting on. The flash should be off camera to one side at a bout a 45 degree angle to the subject. you should get an off camera flash cord like the one shown http://www.spartanphotocenter.com/spec-sheet.html?catalog[name]=Nikon-SC-29-TTL-Coiled-Remote-Cord-flash-cord&catalog[product_guids][0]=08e8b97d-5f2f-4b4a-9ed7-2adb002dd0cf this will allow you to get a more pleasing side light. the camera can be set where ever you are most comfortable.
Posted on Nov 08, 2009
I want to use my nikon d80 with my sb600 and as a infrared remote
The Nikon D80's shutter can be released via handheld "IR" or infrared remote. You can buy them online or in most camera shops. The Nikon branded one will cost the most, but really doesn't perform a whole lot better than the $5 third party versions. The nice thing about IR remotes is that only a transmitter is needed. There's a built in IR receiver on the front of the camera body, and as long as it is not obstructed - or too far from the transmitter, it will work fine.
The SB600 will fire if setup to work correctly when the shutter is released "normally" - triggering with a IR remote will not affect the SB600 flash whether mounted on the camera or if in "commander mode". The D80 manual has details on pg 38 to operate in both the instant and time delayed IR operation modes and should be consulted as Nikon does not allow copy and paste from the manual - and they make use of graphics for button functions.
When distances are too great for the IR remote, you'll need to go the route of an RF or radio frequency remote instead. Many of these will work at distance up to and even beyond 100 yards. They consist of a transmitter and receiver. The receiver can be mounted on the hot shoe of the camera or tethered via cable to the camera body. This is not the question you asked about, so I won't go into further detail - but only mention it as another way of doing the same thing from greater distances or when you can not be in front of the camera to access the IR receiver on the D80 body.
If this was helpful, please rate it as such. Thanks and good luck!
Sep 29, 2011 | Nikon D80 and 18-55mm Lens Kit Digital...
My NIkon SB600 is stuck on my hotshoe-I can not remove it fromt the camera (d80) help
I had a similar problem with my SB25 when I tried to use it on a D90. I took the camera into the Nikon USA Repair Depot in Los Angeles where they took it into the back shop and removed it while I waited without charge. If the SB600 is like my SB700 and SB900's, there is a spring loaded dimple in the camera's hot shoe that clicks into a hole in the SB flash hot shoe. I think if you can slide a thin piece of metal such as a machinists shim, you may be able to depress the dimple and release the SB600. Let me know if it works.
Mar 15, 2011 | Nikon Sb600 Sb-600
Sb600 with D80 on P or A mode pictures comming blue Why? what will be correct settings on both mail me - ravindrahinge@gmail.com
Two steps to correct this: 1) Press the WB button and rotate the command dial untilflash. 2) Press the buttons simultaneously have a green dot .In the first step you set the white balance for nikon flash attach.The second you return to the default or factory settings. Two steps to correct this: 1) Press the WB button and rotate the command dial untilflash. 2) Press the buttons simultaneously have a point verde.En the first step you setthe white balance, the second you return to the default or factory settings.
Feb 15, 2011 | Cameras
I cant get corect skin colour tone in auto white balance.i got some photographs and i see exif data of that photos in photoshop.at the exposure mode it showing manual exposure but at the scene cature type...
You can't. The Portrait mode, like all the other point&shoot modes, are automatic. The camera controls most functions, like exposure metering, auto-focus mode, and white-balance. If you want control over the camera, you'll have to use one of the PSAM modes.
Aug 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Have Nikon D80 with 18-200VR lens. Am getting consistently overexposed pictures. Kindly advise. Thank you
Please check your exposure value (EV) settings. You may have raised this and forgot to move it back.
You should be able to play with exposure also via the Shutter, Aperture and ISO settings
Dec 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
Sb-600 and d80 sync, connecting, off camera..
  1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
  2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
  3. Set the flash mode to Master (do not set it as AA or A)
  4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
  5. On the D80, from custom settings menu, select Built-in-flash
  6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
  7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
  8. Set the channel to the same as in step 4
Now you are ready to use the remote off-camera flash.
Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
Yellow/green tint indoor photo using auto portrait mode
Hi - You can download the Nikon D80 Guide to Digital Photography manual by clicking the link underlined in blue below:
Nikon d80
Firstly see page 58:
Try setting the white balance to fluorescent an compare. Also you could set your own white balance preset by shooting a white card as per page 59. Lastly you can play with the "tone adjustment" on page 80.
Let us know how you get on!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 11, 2008 | Nikon D80 Digital Camera with 18-135mm...
D80 and SB-600 FV Lock doesn't work anymore
In whacky situations like this it is always best to re-set your camera and flash settings. Somewhere on your D80 you will find two function buttons with small green dots next to them. These are the resets. Push both in at the same time until the display LCD flashes.. The camera is now reset to default settings.You will now have to re-set your FV button to the custom setting you had it at before.
Also, reset you flash by turning on the power and removing the batteries and re-install them.
Apr 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Problem shooting portrait
That's just the quirky autofocus of the d80. Try tilting the camera diagonally to focus and tilting back up to shoot.
Unfortunately, autofocus issues like those are the difference between a d80 and a d200/d300 :/
Mar 20, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
52 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
