Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
My dlp tv has a shadow about 6'' wide and full ht of tv
My dlp tv has a shadow about 6'' wide on the left side of the screen, its only 3yrs old. Never dropped or damaged
    Genius:
  • 1,112 Answers
Hello: The problem is that a small mirror on the light tunnel has fell off causing a shadow in the picture,. In the past the only way to repair this problem was to replace the entire Optics Engine. But Samsung decided it was replacing entirely to many light engines so they decided to allow and train technicians on how to do it. It involves removing the color wheel and behind it is the light tunnel where light from the lamp shines on to a maybe 1 1/4 inch small block with three mirrors on all sides, your problem is that one of these mirrors has come loose from its side, causing a shadow with the pic still in the background. So if you call a technician to come, if he has'nt had the training from samsung on how to do the procedure then he will want to replace the entire optics engine which is the expensive way of doing it.
So when calling as if they know how to replace light tunnel. There are some adjustments that also needs to be done once it's replaced. To verify what i am saying go to this site to find out more. http://www.avsforum.com/avs-vb/showthread.php?t=758625
Call if you need more info will be glad to help..
Delhielectronics@live.com
Phone: 702-418-1389
Posted on Sep 26, 2009
3" vertical shadow on left side of screen
Either (on this plasma) a damaged/bad sustain board for left side of screen or a problem with the Display panel--set by model number is 5-6 years old so may or may not be worth fixing.
Apr 10, 2012 | Panasonic TCP50S2 50 in. TV
Bush IDLCD26TV16HD Left side of screen red causing distortion
Check its degaussing posistor at the power supply regulator section.
Apr 02, 2012 | Bush Televison & Video
There has been a gray shadom on left side of screen, maybe 3 inches wide, for the entire length of the screen. I can see through the shadow, but it is noticeable.... any thoughts?
This tv have a colors wheel design in it.Flashes or discolors on this shadow?Tv making any humming sound or motor noises.Yes,mean the tv colors wheel is dying and spinning out of it motor axis.The color wheel,is the problems.Colors wheel sit way back of the tv,must take out alot of mechanical parts to get to it to replaced.U have no mechanical skills,don't tries this.Hire a tv tech to replace the colors wheel.
Jan 17, 2011 | Samsung DLP HL-P5663W 56" TV
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Shadow down left hand side of screen
Is it an LCD or DLP? The Model below suggests it is an DLP. Sounds as if you have the dreaded light tunnel collapse common to all LG DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Jul 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Samsung dlp tv
Yes, it could. There is a light pipe in the light path that could now be broken from the bumping or it could just be out of line from the bumping. Another problem could be the mirrors in the projection path could just need adjusted by the 3 screws that are beside the mirrors. This may also happen when bumped.
Mar 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Two inch shadow on tv
Change the input to AV1 or AV2 with no signal and see if it's still there, if it is you might have a defective light engine in which a lot of manufacturers will warranty. This can be repaired in the home but some shops preferr to take them in, try for the in home co's first. Just a word to the wise, DLP's do not last as long as you may want.
Mar 19, 2008 | Televison & Video
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Nov 12, 2006 | Toshiba 44NHM84 44" TV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
464 people viewed this question
Henry  Thomas
Henry Thomas
