Question about Minolta QMS 2200DL Laser Printer
Magicolor 2200 DL - replace transfer belt
I have just replaced the transfer belt on my magicolor 2200 DL but am still getting the error code to replace it. I have taken it out and tried again, turned it off and on a couple of times but the error code still keeps coming back
  • 3 Answers
Is this an error 16 rorate problem? It does seem weird that you still get it having replaced the transfer unit.
However the printer does have a nasty habit of not re-setting things correctly - it creates the error message by blowing a fuse on the unit and it has been known to do this even when a new unit is put in.
There are a couple of places on ebay that sell a kit that explains how to get to the fuse and they supply a new fuse. It appears to be a 1/4 amp slow blow fuse
To get at it you will need to unscrew a black plastic plate at one end of the transfer unit (it is the one that has a square hole with the main electrical contacts poking through. Loosen the 2 screws and remove. the fuse is on a small circuit board that is easily removed. replace teh fuse (needs soldering) and this might do the trick. If you have a tester might be worth removing the small circuit board (wire connector comes off easily) and checking.
This fues usually blows when the transfer unit is old and a sensor unit gets clogged up. However even when teh sensor and the band at the side of the belt has been cleaned the fuse still sometimes blows.
This might solve the problem.
Posted on Feb 11, 2010
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
My Magicolor 2200 ghosts in color and in black. Ghosting appear about 1/2 way down an letter size sheet. Installing new fuser has no effect.
This is a symptom of a well-used transfer belt. Replacing it should do the trick.
To verify: Check the transfer belt. The transfer belt is the large replaceable unit close to the center of the printer. It should have excess toner clinging to it. Don't bother trying to clean it off. It will just return the next time you print.
I'm currently looking for a way to squeeze a little more life out of it. But, am having no luck so far.
Nov 29, 2010 | Minolta magicolor 2200 EN Laser Printer
AIDC error code
When an “AIDC Error” occurs, do this:
1. Replace the Image Transfer Belt
2. Check to see if the AIDC Sensor is dirty
3. Securely connect the connectors to the High Voltage Unit
4. Replace PWB-A
Aug 05, 2009 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Apr 18, 2009 | Konica Minolta magicolor 2430 DL Laser...
Are you there? I have a problem with a Minolta 2200 as to the error about replace the transfer belt . Can you help
contact minolta tech support coz they will tell you how to change the transfer belt if you do not know any thing about printers get profeshinal help
Dec 23, 2008 | Minolta magicolor 2200 DP Laser Printer
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal error Code 16H
It relates to the transfer belt unit, replace it
Jun 04, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatla error code 16H
May 31, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2200 can't complete warm-up
clean the connectors of the toner cartridge, transfer unit, drum cartridge. did it signal ** toner? replace if needed. check the status of your printer install the printer utility then see the machine status you will see error codes. tell me if what is the code..
Nov 08, 2007 | Minolta magicolor 2200 DeskLaser Printer
Minolta QMS 2200DL Laser Printer Logo
471 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
