Question about Water Warehouse Intermatic Emergency Shut-off Switches
Describe how I would remove my Intermatic fan switch from the wall.
    President:
  • 1,723 Answers
Take cover screws out. Remove screws from switch to box. Remove switch. (power off)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 26, 2009
PROGRAMING SWITCH TIMERS
1) Copy following links to help identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
2) Add a comment and describe timer in detail, including what the timer does, and what buttons appear on timer face, and location of each button.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 15, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
What is the intermatic e 1020 used for just moved into a house andits in the bathroom and makes a lot of noise.
The E1020 timer is reliable heavy-duty 24-hour on-off analog timer with replaceable trippers and manual override, rated 12 amps.
This timer replaces ordinary single-pole on-off switch.
Timer has extra white wire that connects to white neutral wires inside box to run timer mechanism, while mechanical single-pole switch does not need this wire.
I don't know what it is doing... maybe running the vent fan periodically, or turning on attic vent fan?
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
http://waterheatertimer.org/How-to-set-timers.html
For same timer, with less noise, install E1100-1200 aka the KM series in-wall analog timer. Or install digital in-wall timer, or replace timer with on-off switch.
Aug 11, 2012 | Intermatic Timer E1020, Single pole/single...
Do not know how to adjust timer without manual
Timer is not identified.
Check options below:
1) Open following link for ST01C timer
http://waterheatertimer.org/ST01C-program.html
2) Add a comment and describe timer indetail
Oct 08, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
I need to know how to set this timer
Not enough space to copy contents of instruction manual.
Question posted under Intermatic EJ351
Open following links to identify timer and download manual.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Also you can add a comment and say which part of manual is confusing, and I will respond, or take advantage of fixya live phone service and expert can read programming steps to you while timer is being programmed.
If this is not your timer, then add a comment and describe timer in detail for possible instruction manual.
Sep 16, 2011 | Intermatic Programmable 24 Wall Switch...
I have a wall timer which activates a bathroom fan. It was switched on this morning and now it cannot be switched off. How do I switch it off. I do not know the model number
Timer probably needs to be reset, or possibly timer has gone bad or battery has gone bad.
More information is needed.
Let's identify timer, and then possible solution can be given based on that.
If you bought timer locally, what store did it come from?
Add a comment at any point.
Also open timer door to see timer buttons:
Open following link to see Intermatic timer buttons:
At bottom of page are links to more timers.
For example Sylvania, Tork, GE, Utilitec, Aube, Leviton
Aug 30, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I need to reset timer, but lost instructions for Intermatic 3332632 Programmable Timer
1) I believe Intermatic 3332632 is same as EJ351 timer
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
If that is not your timer:
2) Add a comment with photo of timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
3) Add a comment and describe timer in detail.
4) Search Intermatic site
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
5) Open following link and find same-similar timer.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 21, 2011 | Hardware & Accessories
I need to rewire this switch into a light for an aquarium..can you supply wiring diagram
You posted under Intermatic 240Volt T-1906 box-type timer:
Look at model number on inside of timer door.
If this is not your timer, then link below doesn't apply.
Wiring diagram appears on following link:
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
It seems unlikely you have expensive 240Volt box timer for aquarium light.
So add a comment with clear description of your timer/switch.
If you have wall switch instead of timer, please describe the device, and screw colors on device, and wire colors inside box.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on your do-it-yourself project.
Jan 17, 2011 | RTO Intermatic T1906 Elec Mechanic Timer...
How do i remove it from my wall
simple remove the plate then there are two screws that you need to unscrew then you pull the whole thing out.
Jul 12, 2009 | Intermatic Hardware & Accessories
Water Warehouse Intermatic Emergency Shut-off Switches Logo
Top Water Warehouse Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Water Warehouse Electrical Supply Expert? Answer questions, earn points and help others
