Question about Kodak EASYSHARE Printer Dock Thermal Photo
Printer only printing half of picture also paper not always pulling through only printing left side of picture and the rest is blank. Replaced the cartridge and paper. Paper not pulling through right. Sometimes not at all and printer flashes and says to load paper and print again but it doesn't seem to help.
IB4G2008
  • 3587 Answers
SOURCE: KODAK EASYSHARE PLUS SERIES 3
always..did I say always, check for driver corruption when this happens. Remember that photo printers are just scanners turned upside down(just kidding, but it's not that far off). Also, the printer should be on it's own circuit(meaning NOT plugged into power strip same as pc or other devices, especially modems)
Posted on Feb 06, 2008
SOURCE: Printer won't print.
sounds to me like perhaps the printer drivers are really unhappy. you'll need new ones from www.kodak.com
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
  • 31 Answers
SOURCE: kodak printer dock series 3
The problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
SOURCE: kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
Posted on May 28, 2009
Joed911
  • 4338 Answers
SOURCE: changed black cartridge now paper goes through
Print a demo sheet.
1. Verify that inkjet paper is loaded in the paper tray.
2. Press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes green.
Does a blank print appear? If so:
How did the paper exit your printer?
Quickly and smoothly
Slowly and in increments
If quickly and smoothly, contact Kodak at 1-800-421-6699.
To expedite the call, provide the agent with the one of the following reference IDs - PH02 for image quality problems or BP01 for problems with blank prints.
If slowly and in increments, reference BP02
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 06, 2009
When I send my job to the printer. The printer will print but only on 1/2 of the page. it looks like the printer think i want two sheets on one page
Is the whole page you want printed on half the page is just half the data printed? If the whole page is printed on half the paper then the problem is software. If the page only prints the left side or the right side blank on the other side then the problem is most likely the fuser assembly. Can you take a picture of the page and email it to us, we will email you back with what needs to be done next.
Tech@ccl-la.com
Apr 30, 2010 | HP LaserJet 2300 Printer
Kodak Easyshare printer prints only the left side
did you ever get it fixed? im having the same problem....
Apr 29, 2010 | Kodak EasyShare Color Photo Printer Dock
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Picture only prints on one half of page
Try printing a testpage just press print + cancel and make sure you have a paper loaded
Nov 15, 2008 | Kodak EasyShare Thermal Photo Printer
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Resume button is stuck
i think you have aproblim with the main card in side the printer
Jan 11, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Labels Print Once Then Fail (3.5 X 1)
"The printer will print one label then either push out a half a blank label or several blank labels. At that point the labewriter thinks it's out of paper. I also noticed that the labels tend to slide toward the middle while exiting. After each print I have to pull the labels back in and realign them. Then the process repeats."
This is because you haven't squeezed both sides of the spool to the edges of the label. Without the sides to hold the label in place it is free to slide about on the spool and therefore slides about where the print head and label sensor are. The sensor is on the left, so if it slides towards the middle the sensor can't see the label and reports "out of labels".
See the diagram here for a clear picture of how to correctly load the labels to avoid this problem:
How to load Dymo LabelWriter Labels
Nov 06, 2007 | Dymo LabelWriter 400 Thermal Printer
Print on left side of paper
The printer needs servicing , either transfer roller or the laser scanning unit needs servicing to clean dust/humidity.
omnipresent
Nov 04, 2007 | Samsung ML 2010 Laser Printer
Okidata 3410 pacemark not printing correctly
Well, I had that problem once. What I did was that I used the printers cleaning tools. You can acces them by entering Printers in the ControlPanel. Then right click on your printer and select Settings. Look through there. Worked for me.
Apr 06, 2007 | OKI Pacemark 3410 Matrix Printer
Kodak EASYSHARE Printer Dock Thermal Photo Logo
83 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
