Question about John Deere Garden
Our j-d 345 lawn mower tries to start but it seems
Our 1995 j-d 345 lawn mower tries to start but it seems to be getting no spark the lights on the console work ,,,is there a fried fuse or bad contact switch. it ran great till we went to start it today and no go.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Time delay module?Does it seem to crank faster?
Posted on Nov 13, 2009
Will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 | Garden
Model 20199 used once and will not restart.
Did you take the spark plug out and touch it to a bolt head while pulling the cord? if you did you should see a small spark jump between the plug center electrode and the ground electrode. if you do not see a spark you either have a short in the plug wire or the coil is faulty.
Jul 18, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
Craftsman lawn mower won't start, low oil light is on, dip stick oil level is correct
Get some marvel mystery oil drian oil put in mystery oil let sit one hour with spark plug wire off try to start what this doses is clean the in sides ,do this about 10 times trying to start. Dump out mystery oil put new oil in don't over fill good luck
Jul 15, 2014 | Craftsman Garden
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
No spark
DO NOT DISABLE SAFETY SWITCHES, which riding mower company i will try to get the answer for ya
Apr 13, 2014 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
Toro Mower wont start
take sand paper and shine up the magnetio with is on the flywheel shine them up and put you hood back on it it will start
May 12, 2013 | Toro Garden
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
Lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
May 29, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
522 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
