Question about Seagate USB 2.0 External Enclosure + 300GB BARRACUDA 7200-ULTRA ATA/100 8MB-ST3300831A (NEWITEM31866554) Drive Case
I have a seagate ultra model 300 gig external hard drive. I dropped it and now the blue light stays on and does not show hard drive light on. Is there a way to retrieve data from drive? Thanks.
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
If nothing works , it would be best to take the drive to data recovery experts.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
I have a Seagate external hard drive model # 9w6044-540. I need to know what kind of drive it has, how many gigs it is and what size disc it uses.
If you take it out of the case, there will be a sticker on the drive with all the info. I do know it's quite a few years old tho. Somewhere around 160 gig I think.
Feb 01, 2015 | Seagate Computers & Internet
I have a seagate external hard drive that I dropped, and now the blue light stays on, but the computer does not recognize it. is there a way to retrieve the info?
Are you using XP?
It should show up. Are yo sure you are plugged in correctly everywhere?
Check your device manager ...
Let me know if this works for you.
a
Sep 26, 2009 | Seagate USB 2.0 External Enclosure + 300GB...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500 gig external hard drive problem
Your computer must have a firewire connection.
Jan 11, 2009 | Computers & Internet
Seagate 500 Gig External Drive disappeared !
external harddrive turn them selves off after 5 minutes if it isn't being used.
Aug 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Slightly dropped seagate external hard drive, recover data??
please use stellar phoneix software
that will do your job surely
Mar 16, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Jan 30, 2008 | Seagate (ST3300601U2-RK) (ST3300601U2RK)...
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
How to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
May 02, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Computers & Internet Logo
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
