Question about Kenmore Refrigerators
My frig is not cooling..or freezing. the light turns on....but no cold air...or air pressure?
dididsaythat
  • 291 Answers
SOURCE: Kenmore Refigerator
Is your fan in the freezer blowing, condenser need cleaning, condenser fan working, any frost build up in freezer? controls set in the middle?
Posted on Aug 27, 2007
Buffalo12980
  • 625 Answers
SOURCE: Jenn-Air JCD2389GEB side by side
the clicking noise is the motor overload. have a service tech check for a freon leak.
Posted on Sep 24, 2007
SOURCE: freezer freezes, refrigerator is 55 degrees
All refrigerators also have a return air vent. You need to make sure this is not blocked by frost, the units own foam insulation or even by product placement. You should find it behind the crispers in the bulkhead between the freshfood and freezer compartments. You also want to verify the supply duct behind the damper is not blocked.
Posted on May 03, 2009
  • 235 Answers
SOURCE: the freezer is cold, but frig will only go down to 41-43 deg rang
Make sure both condenser and evaporator fans are running. Is it possible that you might have something blocking the air flow from the freezer to the fridge?! Can you hear the fan running up on top?
Posted on Jul 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
We bought our frig exactly 6 years ago (to the date!) and suddenly the frig part is cool, but not cold, while the freezer section stay cold and ice is frozen.
Check your freezer section ! Is the coil frozen over ? If so it may have a burnt out defrost element or a bad defrost timer. When the freezer coil freezes over cold air is restricted to the refrigerator section.
Jun 03, 2011 | Refrigerators
Kenmore coldspot - freezer stays cold, but frig isn't
If this model is a frost free, you probably have a bad defrost system. That would make the unit freeze up and cold air can not get through to cool the unit properly.
We have parts and supplies, so please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We look forward to working with you.
Nov 05, 2009 | Refrigerators
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have an amana side by side refrig, the frig side cools a little
sounds like yhour compressor is not runnning, look behind the unit and se of the fan down below is turning and if the compressor is cold, or overheated and redhot
Mar 09, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
No air movement in frig and does not cool or freeze
you need to get a tech to look at it it sounds like a sealed system issue Compressor,drier etc....
Nov 12, 2008 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
16 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
