Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Sometime when I am vacuuming carpet or a large area rug, my Dyson starts making this loud, horrible, wrenching noise. It stops when I lift one of the wheels up. What is causing this? I have only used my Dyson 3-4 times.
  • 121 Answers
You will need to have the clutch replaced. this is causing your problem.
Posted on Oct 13, 2009
I have a huge area rug, I cannot even push the vacuum because it sucks up the rug. what can I do?
This vacuum is not made for the new soft carpets
only special vacuums are recommended by the rug Manf, Emer Vacuums USA
Here is a link for these vacuums
Jun 28, 2015 | Dyson DC28 Animal Bagless Upright Vacuum
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
When in carpet mode, brushes seem to be hitting something. Brushes cleaned - how to stop making the awful noise
LOL do you mean when you move the vacuum forward (say into a baseboard)? it makes the loud shocking noise.. i hate that too.. but that's the crazy Warning sound indicating something is stuck (like you sucked up an area rug) or you have run into something and it set off a sensor.
Mar 26, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a Dyson Animal. Roller bar won't turn/belt intact
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Apr 12, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Loud noise when I start the vacuum in carpet position
It's most likely the Belt Slip Protection Dyson uses to prevent the user from having to replace belts. I recently bought a Dyson and love it other than it literally sits there and makes horrible noises 80% of the time. I completely disassembled the vacuum and found that the spring they used for this belt slip protection is WAY too weak. The weak spring seems to let the belt slip protection pop off way too frequently and unnecessarily. I stretched the spring back out and whammy no more horrible clanking. Of course it'll take you a couple of hours, some good tools and some serious ingenuity to get to where the parts are but problem solved. It'll still ratchet when picking up a sock or dog toy or something, but sitting there ratcheting on short dense carpet is unacceptable. Hope this helps!!!
Feb 14, 2009 | Dyson DC14 All floors Bagless Upright...
Not exactly a solution, but more of an explanation. The noise is caused by a ratchet device that's designed to protect the belt if the brush roller becomes blocked. It's a bit like a clutch that slips when resistance on the brush gets too great. The noise will occur if there's a solid blockage, of course, but it will also occur whenever the machine senses excessive resistance. This may happen on carpets with really thick pile, but can also happen if the carpet is loosely fitted and can be sucked up tight to the roller by the force of the vacuum.
Small consolation, but the problem should lessen as the brush wears. Meanwhile, if all else fails, switch the brush off (hard floors mode) while vacuuming the problem carpet(s).
Feb 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Loud noise
This is the clutch as it jams up in the brush. Usually happens with rugs that are not secured to the floor.
Dec 11, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Nov 11, 2007 | Dyson DC14 Full Access Bagless Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
220 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
