Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
There is a repetative clicking sound whenever I use the treble on my guitar. what is causing this?
    Novelist:
  • 133 Answers
Did you mean the treble control potentiometer (knob)?
This was posted as an amplifier problem, but since you mentioned that the use of the treble (button?) on the guitar is causing the clicking, i would have the treble potentiometer checked first.
It could have a loosely soldered or broken wire on any of the tabs, oxydized slider contacts, bad ground (negative) connnection, possibly dirt or damage on the resistive track inside the pot.
A broken wire can easily be resoldered, but if there is internal damage or oxydation, the potentiometer should be either cleaned or replaced.
In short words - it may be a faulty treble pot.
There are ways to disassemble and clean a potentiometer, but the difficulty of this task may vary and depends mostly on the type and build of the pot.
The other alternative is to have it replaced.
regards
Triarcuate
Posted on Sep 26, 2009
Dean razorback db electric guitar knobs
the knob closest to the neck is your volume. And the other two are tone. one is tone for bridge p/u & other is tone for Lead p/u. which is which can vary. you'll just have to listen. hope this helps
Jan 31, 2012 | Dean Razorback Db Electric Guitar
What are the control knobs on a fender usa telecaster for. explain each knob please
The one furthest from the switch is volume. The next one is a tone knob. Volume rasises or lowers the resistance and makes the guitar louder. You can also "clean up" a distorted tone by rolling off volume. Tone makes the sound more bassy or more treble.
Sep 03, 2011 | Fender Musical Instruments Corporation...
Hot rod deluxe squeals terribly with either overdrive box or distortion box. seem fine with tremolo or chorus box.
I have had this problem at least two times and the fault was a bad hi voltage filter capacitor. With the back of the amplifier removed, it's the grey cap near the top right side. Warning: very dangerous voltage there!!
Jul 20, 2011 | Fender Hot Rod Deluxe Guitar Combo...
The high E string dont sound as brightly as the rest of the strings when plugged. I already changed the strings several times with different brands. still the same problem. only the first string sounds...
This is likely a problem with the amp you are using. Turn the treble up higher. If the amp is intended for a bass guitar, it probably can;t handle the highs of the E string. In that case get an amp that has a smaller speaker or one that is intended for Keyboards that has the capability.
Jun 19, 2011 | Yamaha SLG100N GUITAR ESSENTIALS Bundle
I got a Marshall MG100HFX Amplifier for guitar. The problem is that whenever i turn treble switch on it gives clean sound as it should, but in couple seconds it fades away. When I turn the switch again it...
I haven't played or worked on a MG100HFX but I understand amp circuits very well. The behavior you are describing sounds to me like a bad capacitor in the Treble circuit. This is a problem that would require the skills of an experienced amp tech. If you are within your warranty period you might want to return it. If not, a good local repair shop should be able to diagnose the problem.
Good luck and keep rockin'!
Mar 01, 2011 | Marshall Amplification Marshall MG100HFX...
This bass squels if you have a bass head and cabinet. i had a 100W amp and it played fine then upgraded to a head/cab. tryed playing it with loud volume, squels. anyway to fix this?
Turn down the treble gain and mid gain... you don't need it for a bass. Prevent the guitar from "hearing" the output of the amp directly. The guitar strings make a good microphone.
Feb 27, 2011 | Epiphone EBO Electric Bass Guitar...
Bass strings are too loud in comparison to treble strings whe played through the amp
Adjust this using the EQ on the amp and to a lesser extent the tone controls on the guitar.
Often people boost the bass way up causing this problem.
Feb 12, 2011 | Epiphone Sheraton II Guitar Electric...
I'm having some crazy feed back with either my amp and i'm not sure what its from or if its my guitar but, every time i go to practice or to play a show i kill peoples ears. Now i play death metal and i...
If the guitar can "hear" the sound, the strings can resonate from the sound and result in feedback. Running at maximum gain is asking for trouble. That causes distortion which drive the speaker as a square wave and worsens the problem. Also back off the treble as you can have supersonic feedback that you can't hear but will heat up your amp.
Test by allowing the feedback and then dampen the strings... if this stops the feedback you need to move the amp away from the guitar. Being a passive pickup makes NO DIFFERENCE about the problem.
Nov 22, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
After about 30 minutes of playing i get a drop in bass power a drop in volume also a destorted sound occures during that period i tried changing the battery i still get the same problem i have a schecter...
Have you checked that it is not the amp that is the problem? This is a fairly common thing to have the amp heat up and the thermal protection shut it down partly. Since the bass drops, a loose connection or bad guitar cable can cause that. If the signal becomes capacitively coupled only the treble will come through and be very distorted. Try a new cable. For the guitar, open the electronics area and look for loose or broken wire.
Oct 25, 2010 | Music
When I lower the bridge of my ibanez grg170dxbkn to the required action of the strings(2mm bass)(1.5mm treble) my strings on the treble side produce a buzzing sound mostly on the 12 fret...do i need to...
I can understand it a bit of a daunting task setting up these guitars (I have bought at least 5 like this) But yes it might be the truss rod ... Without looking at the guitar myself its hard to say ... If you tighten the truss rod remember how much you turned the allen wrench because if it doesnt work your going to need to reset it and start again ... Remember to turn it the right way! and if all else fails ... If your near me (Bournemouth, South of the UK) then you can always pop on over to mine and I can take a look at it.
Failing that just take it to your nearest guitar repair shop and a setup should cost you about £30 if your in the UK.
Apr 07, 2009 | Ibanez Grg170dxbkn Electric Guitar Hsh...
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
139 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
