Question about Linksys Wireless-G Broadband Router
Status on HW550-3G : No Modem / Unsupported Modem
Anybody know how to setup this router (HW550-3G). during setting, they need dail no, username, password and SIM PIN. how to get the information? or no need the informations.
  • Linksys Master
  • 8,404 Answers
This machine should run right out of the box.
No user normally required
No pass usually required
If there is a pass ... it is usually "Admin"
Get Network Magic, the free evaluation copy, to fulfil all your network management needs. After a period, it will reduce functionality but still do nearly everything yhou will require. I use the paid pro version and I love it.
Network Magic will provide you witdh a license for up to 5 computers. It will run from any or all.
Give it a spin
I hope this helps you
a
Posted on Sep 26, 2009
I cant access internet with router but I can access with direct connect to verizon modem
You may access the setup page of the router and make sure it is configured properly.
To check the configuration on the router, access the setup page by using a web browser. Type 192.168.1.1 in the address bar.
Leave the username blank, and the password is admin.
Once in the setup page of the router, select the connection that your ISP is using.
Usually, Verizon uses PPPOE connection. Type your Verizon username and password (this is sometimes your email address, if not sure, contact Verizon). Then click save settings.
Go to the status tab, and click the CONNECT button.
Let me know if this works. Good luck!
Dec 05, 2010 | Linksys WRT160N Wireless Router
Lost my book
You may access the setup page of the router to get the network key. You will need to use a computer hardwired to the router. Check the ip address of the computer (control panel -> network connections-> right click Local Area Connection and select Status) and take note of the default gateway.
The default gateway is the ip address of the router.
On your browser's address bar, type the default gateway, usually it is 192.168.1.1. It will ask you for the username and password.
By default leave the username blank then the password is admin.
Once on the setup page, go to Wireless -> Wireless security. You will see the network key on this page.
I hope this helps!
Apr 19, 2010 | Linksys Wireless-G WRT54GS Router...
I have recently been sent a Netgear WGR14v9 and when I connect my Vodafone Gateway (Sagem BSR Femto Vodafone UK) it won't work, any suggestions or solution to this problem is much appreciated. Many thanks
Well Vodafone is a DSL connection, Do u have a modem or not, If u dont have modem then this router won't work,and if u have modem
- router page - http://www.routerlogin.com
- username and password is admin and password.
-- run the setup wizard
-- Apply the basic settings
-- change the wireless settings
-- check the router status in left side
-- u need a ip address under Internet port in router status.
-- try to connect all the wireless computer
Jan 18, 2010 | Zyxel Prestige 334W Wireless Router...
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it...
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
I connected adsl cable but no internet connection. My old external modem still works ok, so no issue with telephone line. Do i need to configure router?
Yes - find http address to access the new modem via your computer (something like http://192.168.0.1 - varies according to model) using Internet Explorer. Go to where you can put in your username and password for your ISP (your Internet supplier), and put them in. This will be something like your.name@tiscali.co.uk (or whomever) and the password you would use to access your ISP email or webpage for your internet account. The new modem needs to know who to connect to and how to get in to your authorised inernet supply.
Sep 07, 2009 | NetGear DG834G Router
The modem's been changed and cannot locate the CD to the driver to connect to the internet. The model is DSL-G604T/AU V.A3.
Hi! your dlink dsl-604T is adsl router modem, you can access the setup page of your modem router by connecting your computer directly to the port1 of the modem router and the cable from your isp should be connected to the WAN port. u need to pull up the browser and type in at the url:192.168.1.1 and it will ask the username and password, by default the username is admin and the password is 1234 or leave it blank, but i suggest before u do this steps. u need to reset your modem/router. there is a reset button on the back of the router and press it for 20secs and then unplug and replug it after 10secs. after that u can pull up the setup page of the router.. to check the default gateway of the router, right click the network icon on the lower right of the task bar and select status and it will show the ip address, subnet and default gateway..
u need to know what internet settings u have with your internet provider, bcoz once u access the setup wizard it will ask u the type like auto-dhcp, pppoe, static etc.. if your isp gives u a username and pass to connect to internet u have to select pppoe or if u are given a static ip address setting u need to select static ip... just follow the setup wizard..
Aug 17, 2009 | D-Link DSL-G604T Wireless Router
No access through D-Link DIR635 - Modem speedstream 4100
Hi! try to reset the router for 10secs that is located at the back of the router..then connect your computer directly to the router and pull up the browser and type in at the url:192.168.0.1, it will ask u the username and password, username by default is admin and the pass, just leave it blank, then it will show the setup page of the router..try to check this first in order for you to setup the router so that it will talk to the modem: if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Aug 08, 2009 | Computers & Internet
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Have second hand dlink dsl502t modem am trying to access modem to change settings. the modem is unsupported by my isp but they have told me it will work but i need to access the modem and enter my user...
Open a web browser (e.g. Internet Explorer, Firefox or Opera). Enter the IP address of your router in the address bar of the browser and press enter. The IP address of your router is by default 192.168.1.1
You see a box asking for your username and password.
By default the username and password for your D-link DSL-502T router are both admin
Enter your username and password and click the ok button to continue.
Jul 14, 2008 | Computers & Internet
Router as cable modem
This answer is for a Dynamic and Static Cable connection (I.E. ATnT-BI, Cox, Adelphia, Rogers, Roadrunner, Charter, and Comcast). Note: Please configure the router with the computer that was last connected directly to the cable modem. Step 1: Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click on the Basic Setup tab. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Save and Restart. Step 3: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4: Follow Step 1 again and log back into the web configuration. Click the Device Status tab . If you do not already have a public IP address under the WAN Ethernet heading, click on the DHCP Release and Renew buttons. Setup Static Cable Connection Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click the Basic Setup tab. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. Note: If you do not know your settings, you must contact your ISP. Step 3: Click on Save and Restart. Step 4: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Power cycle the cable modem and router. # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Linksys Wireless-G Broadband Router Logo
439 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
