Question about LG Flatron L1715S 17" LCD Monitor
Fuzzy picture and in a different language
The picture on this monitor just want from a clear picture to a total fuzzy one. I tried to acess the menu and the language has now changed from english to something can't read it due to the fuzzy ness. Any one have any ideas or should I send it in to a repair shop?
Click on "menu".
then move to the "hand" while clicking on lightview
then clivk select/auto
it should automatically select the third from above
then move to the top while clicking on lightview
and now change the language with the "sun" buttons
Posted on Apr 17, 2008
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Change language to English on the gateway dcdi
To change the language you need to press Menu button on the Monitor bezel , select Advanced, and select language from it using + and - button on the Monitor bezel. After you highlight Language press Menu button again , and select English from the list.
May 25, 2014 | Computers & Internet
My menu monitor setting is not in English, how do I change the setting back to English? Also the picture on the monitor has shrunk, how do I get it back to full screen?
click start control panel,regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don
Feb 23, 2011 | Emprex LM1704 17" Monitor
I accidentally changed the language on my monitor how do i change it back to original settings
If you need to change the OSD language for the monitor, press Menu (the rest of the buttons will light). Then press Main Menu and select Advanced (it is the second from the bottom) Press Choose and then Select. The line to change the language, go to the second line (from the top), use the Adjust button to scroll through the available languages. Press Back to return to a previous menu; press Menu Off to exit.
If the language change was in the OS of the computer, it will depend on OS. In Windows, the Control Panel is the starting place. Then Clock, Language, and Region. The Region and Language area will have a keyboard language and display language (if multiple languages are installed) tabs in Win7. (The older versions of Windows are similar.)
I hope this helps.
May 12, 2010 | Gateway FPD2275W LCD Monitor
It has a very dark screen, I can barely see my
Check the pins on both end of the connector, make sure they're straight other wise, reposition it with fine long nose pliers. Make sure the connectors are push and screwed tight also. Let us know!
Oct 10, 2009 | Samsung SyncMaster 205BW LCD Monitor
Everytime I turn this monitor on all I get is a fuzzy picture. I have tried all the menu settings to no avail????
HMMMM....have you tried unplugging it/taking out the battery and hangging it upside down if its a laptop if its a desktop let it sit the laptop thing works
Aug 16, 2009 | Compaq 7500 17" CRT Monitor
My menu is in Chinese, how do I change it back to English when I can't read the menu options?
If you open up the menu, there should ( Most monitors have little pictures next to the title of the section ) be a picture of a little person with a speech bubble next to it. Go to that one, It's the language selection. English SHOULD be in English, so you can tell which one to choose.
Jul 06, 2009 | Computers & Internet
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
The display samsung t240hd monitor randomly/intermitently loses sharpness. Goes from a perfect hd picture to a analog type picture. White space on menu bars in pc modes goes from a crisp solid grey...
Hi im josh in cebu phils. may i help? Friend your problem focusses on to hardware. first try to check your video card clean or change then after try to use the monitor.if it still appears the same. 2nd try to use your monitor in other pc.if still appears. the problem is your monitor. if you knew somebody around that could fix tv or appliances let him see your monitor.there maybe one of the capacitor in the monitor that is damage or burn out.let him change it. so that it will work again in condition. good luck.
Feb 17, 2009 | Computers & Internet
REDDISH Screen with Samsung Monitor
You should changes the connections first!!!
Monitor connected directly to TV/ CPU without passing the projector unit.
I think that's the problems!!!
Dec 19, 2008 | LG Flatron F700B 17" CRT Monitor
LG Flatron L1715S 17" LCD Monitor Logo
220 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
