Question about Stanton C.304
Stanton rm-3s Same exact damn problem!!!! I bought a mixer on e-bay sender did not send power supply. I bought i generic power supply at Radio Shack, power is on but all inputs do not function please help!!!!
Make sujre, it is a 1amp power supply
Posted on Sep 22, 2011
WHAT R stanton rm 402 ac wireing diagram
Contact the manufacturer or try an on line search with Google!
Jun 03, 2014 | Audio Players & Recorders
How to listen thru headphones using a yamaha emx 88 mixer
Did sound for a southern gospel group, using a yorkville powered mixer. Not familiar with your mixer, but, on the Yorkville I had an unused 1/4" line level output with the monitor mix on it. I bought a cigar-sized, 3-channel headphone amplifier / splitter from Radio Shack, called a Boosteroo. Has 1/8" stereo plug that I adapted to the mono output, with a 1/8" stereo to 1/4" mono adaptor. It receives the line level (monitor in our case) signal and supports up to qty 3 - 1/8" plug headphones. Battery operated. No volume control, so I added an inline dial (rheostat) volume control cable. Can't pull up on Radio Shack, now, but, found it available, elsewhere, online. Worked great for me!
Good Luck SdDude
Feb 19, 2012 | Yamaha Emx88s Powered PA Mixer System
I am looking for a power cord for a sony zs-s2ip boombox. where can i get a replacement or is it generic?
Not knowing what country you're in...
Does it LOOK generic? Then it is. Take it down to an electrical supply store or Radio Shack or look around online. "generic power cord"
Aug 24, 2011 | Sony CFD-G50 Cassette/CD Boombox
I have a Behringer xenyx 802 audio mixer and have lost the power supply. I tried to buy a replacement, but cannot find any in stock. I'm very resourceful and thought I'd make one. The spec sheet calls for...
No, you can't just jump the pins together. The power supply in the mixer needs two separate 18-volt AC inputs because it makes two supply voltages, +15 and -15 volts.
The external supply is just a potted 36-volt transformer with a center-tapped secondary. I bought an open-box Behringer (not your model, but similar) that was missing its supply, and found this transformer which works fine. (I actually did find a couple of sources for a replacement Behringer supply, but it cost more than I paid for the mixer!) Just connect the three output leads to the appropriate places on the mixer's PC board. In mine, I removed the original input connector and soldered a pigtail with a 3-pin connector from Radio Shack to the PC lands, then attached the matching plug to the transformer leads. You'll also need to provide an enclosure of some kind to prevent contact with the line voltage input to the transformer and to protect the thing if you carry it around.
Mar 29, 2011 | Audio Players & Recorders
When the machine is powered on it displays an error on a grey screen saying the divice in the system bay cannot be identified, it may not be properly inserted or may have some errors, option 1 press...
Damn i have exactly same problem. i bought a new DVD writer and slided the same into the media bay. But now when i try to boot up i am getting the grey screen with 3 options.
Thanks in Advance.
Sudesh
Feb 18, 2011 | Dell Latitude D600 Notebook
Cant find a power supply for a phonic 3243 mixer
your can get universal power supplies from radio-shack and wal-mart. try that there about 15-20$
Jan 30, 2011 | Electronics - Others
The power does not come up..I bought an after-market power supply that seems to fit at 6V from Radio Shack..but it appears "dead".
One of the sites indicates this takes a 12 VDC 1.66 amp supply and would have to be the correct polarity of course... Read the nameplate on the unit to find what the requirements are. Polarity is critical and damage could be done if wrong one is used.
Dec 28, 2010 | Innovation First Merkury Innovation Dj...
Need one 12v 2500mah power cord for flat screen monitor xenon is the brand name and is prob kinda old cheap if possible
I had a similar problem. Here is what I did:
I went to the computer store and I did purchased a generic Laptop power supply that provides 13 Volts @ 2Ah. y display was working fine with it.
You may be able to take the display information (Voltage, amperage, connector size, positive and negative information) and get assistance from a computer store (maybe radio shack, circuit cit... oops, they closed stores, never mind that one. Best buy or any electronic store in your area).
If that doesn't work or you can't get a similar power supply, you can check in e-bay and get one similar like this one:
http://cgi.ebay.com/12V-DC-Power-Supply-4-Amp-12-Volt-Adapter-LCD-CB-4A-HP_W0QQitemZ380155972539QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item58830fcbbb&_trksid=p3286.c0.m14
but you need to be sure about the positive and negative connector.
Good luck.
Sep 08, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Radio shack pro97
I have the same issue, was working fine, then the scan works but never stops on any freq. nor does the squelch make any sounds. The only sound is the key tones, I have reset the unit and tried new batteries and a different antena. still nothing? any ideas?
Feb 24, 2008 | Radio Shack Pro-97 Handheld Scanner
Power cord Cd player mod. #CD-1095
Answer below from:
http://wiki.answers.com/Q/How_do_you_get_a_cord_for_a_Durabrand_CD_player_model_cd_1095
You can purchase a generic power cord at Radio Shack. I had the same exact model and found that their catalog number 61-2875 was a perfect fit. It lists for $7.99. To be sure, take your radio in for an exact match. Good luck! :o)
Nov 19, 2007 | Durabrand CD-203 Boombox
Stanton C.304 Logo
399 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
