Question about Casio Parts Cash Register PC Desktop
Replacement of thermal printer . Printer is burnt and I need to replace it . Can I do it ?
    Scholar:
  • 90 Answers
Sure. Why not? Cool with me.. A few things first. make sure if its one of those that uses AA cell batteries, and put in fresh ones. Do this while the machine is plugged in. Next you have to see how to disconnect it. Some time when you are lucky you can see the connector in easy access. Other times you may have to crack the cabinet. Be really really careful, don't force anything and, if you arent sure draw it out first. If you aren't scared enough yet to take it to the dealer go for it. The most mportant thing is to tell me the make and model number
Chris
Posted on Sep 26, 2009
How do you replace the thermal roll to get it to print
Make sure you are using thermal paper which is 57mm wide.
Open the printer cover. Lift the paper holder lever on top of the printer. Remove the old tube from the last roll if it is still in the bottom of the printer. Drop the new roll into the roll holder in the bottom of the printer. Make sure the paper is coming from the bottom of the roll rather than off the top as it unwinds. Pull the paper out the front of the printer and close the paper holder lever down onto the paper. The shiny side of the paper should be facing you as it comes out of the printer. If not, the paper will feed out blank during printing. If you are replacing the journal roll, slip the end of the paper into the slit in the takeup spool (black reel) and wind over a couple of times before dropping into place. Replace the printer cover and make sure the receipt comes out of the cut out in the cover.
Good luck.
Jul 11, 2015 | Casio PCR-T2000 Cash Register
Error fuser unit hl-5350Dn
The fuser unit is located at the rear side of the printer.
Fuser unit error indicates one/more of the following.
1. The fuser roller/film life is over. Replace with new one
2. The fuser film is torn. Replace with new one.
3. Fuser heater is burnt. Replace the heater.
4. Fuser thermal sensor is open. Replace it.
sonsunny
Jun 28, 2011 | Brother HL 5250DN Laser Printer
DO I NEED INK REPLACEMENT?
All you need to do is CHANGE THE BATTERIES! This is a thermal printer that does not use ink, BUT...when the batteries are old/weak they will not generate enough voltage to heat the thermal cartridge paper properly, resulting in faint, poorly printed letters.
Jul 14, 2010 | Dymo LetraTag QX50 Thermal Label Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
How to replace toner cartridge in srp-350 thermal printer
If it's a thermal printer, it doesn't use toner, just thermal printer paper (Like fax paper), It's a paper that turns black on heat contact. It doesn't require any ink.
Nov 03, 2009 | Samsung SRP 350 Thermal Printer
Oki dp5000 thermal printer
Try cleaning the print head as described in the user guide. There could be old ink clinging to the head. If this doesn't take care of the problem, you could have a burnt element, which is non-fixable problem.
Sep 01, 2008 | OKI DP7000 Thermal Printer
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
