Question about Panasonic SC-AK340 Shelf System
  • 1 more comment
  • Anonymous Oct 20, 2008
    when i turn the system on it shows F61 then turns itself off. could this be that i have wired the speakers up wrong
  • Anonymous Feb 11, 2009
  • Anonymous May 04, 2009
    Error 61- Did changing them out help?
  • 39 Answers
This is error code which system control detected either power irrgularities or dc voltage is detected from the speaker out put line.This fault we have noticed that both of them appears same time also.Pls change Amplifier ic TDA8920 and C1740 transistor and 27V1w zener diode.Transistor and zener diode is for voltage regulation and amp ic if the dc detect is active.Usualy change this three components same time.(this all is in power amp section)
Posted on Dec 17, 2007
  • Gopal Vekaria Dec 17, 2007
    transistor no q5110 and diode d5102 change and tda8920 change
My problem F61 home teater system what i can do it plz
Posted on Feb 18, 2008
Panasonic error f61
If you do not know what an audio output IC is, what would ordering one do for you? And unless you have the know how and special gear there is no freaking way you could ever replace it.
Either have someone repair it for you or go shopping.
Aug 17, 2017 | Audio Players & Recorders
How do i fix an error code f61 for sa ak40 panasonic stereo
There is most likely a short in the amp that needs to be repaired.
Mar 13, 2013 | Audio Players & Recorders
My panasonic stereo system SC-VK550. my cd is no open show in F61 Other not open my plyar what is this F61 How to my problem sholf how.
F61 usually means the amp has detected a short or has a microprocessor error.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Mar 15, 2011 | Panasonic SC-HT700 System
When i turn my cd stereo system, it doesn't work,only shows f61 and inmeditly powers it off
I suggest you Google Panasonic on your computer and pose your problem to them. They will tell you what the code means and what needs to be done about it to make the stereo work properly.
Jim Hart
Jun 20, 2010 | Panasonic SC-AK640 Shelf System
Error F61 on Panasonic Stereo System SA-AK80
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Stereo does'nt stay on you turn it on and it just clicks n goes off technics dv290 system
problem with amplifier contact dealer,i have the samne problem with mine,its shows F61 on the diplay and when i check my user manual it states there is a problem with the amplifier
Dec 09, 2009 | Technics SC-DV290 System
F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Sep 06, 2009 | Panasonic SC-AK640 Shelf System
Error f61 on a panasonic SK-AK640 CD stereo system
when i turn the power on , it goes off in 3 sec after displaying "f61"
May 31, 2009 | Panasonic Audio Players & Recorders
Press power it shows f61 instead of what it should show
You need to open the back of the system and change the fuse located on the right side of he panel. you can go to Radio Shack and get the fuse for $1.99.
Apr 06, 2009 | Panasonic SC-AK78 CD Shelf System
Probaby needs the output ic. F61 is an output/power error code. But check that the fans turn before trying to replace or taking it in to be fixed. If a fan is not turning you will get F61 too.
Feb 21, 2009 | Panasonic SC-HT441 Theater System
Panasonic SC-AK340 Shelf System Logo
833 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
