Question about Nikon Coolpix 8700 Digital Camera
Camera wont turn on
Took the memory card out, and put back in..now camera wont turn on at all. I checked the battery its fully charged..nothing will happen at all its like a dead camera.
jackboy
  • 2985 Answers
SOURCE: my nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Posted on Aug 05, 2007
  • 3 Answers
SOURCE: BATTERY dead. how to charge?
The battery is removable and the camera came with a charger that you connect the battery to and plug into a household socket.
Posted on Mar 20, 2008
SOURCE: Camera is not turning on; no power
plug it into the computer. Thats what I did with my camera(even though its different).
Posted on Mar 31, 2008
SOURCE: water damage
There are micro fuse on main PCB of camera first check it. If problem is still not solve than do let me know regards
Posted on Jul 21, 2008
Sailorm0on
  • 61 Answers
SOURCE: black screen, not taking a picture
please check if the camera is in video mode. Just click on the button to switch from picture view and camera
Posted on May 16, 2009
Power problem
HI,
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
May 24, 2008 | Canon PowerShot S30 Digital Camera
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
My nikon coolpix 8400 won't turn on, I took out the memory card to develop some pictures then I put it back in and then the camera wouldn't turn on all of sudden,it has never done this before! do you...
Make sure the battery is fully charged. If it isn't then charge it up and hopefully your problem is solved. If it is fully charged take it out of the camera for a minute or so then put it back in. Try turning the camera on.
Dec 05, 2010 | Nikon Coolpix 8400 Digital Camera
My Nikon Coolpix S8000 will not turn on. I started using it for the first time this morning and took about six pictures with it, then I removed the memory card in order to upload the pictures onto my...
Make sure you insert memory card correctly, when it is fitted into the memory card terminal it give clicking sound. Second thing you can check battery, Direction of your battery might be wrong (+,_), Check out and put it again. Load new or fully charged battery. Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
Else your camera need to be repaired.
Thanks...!!
Rating the solution is highly appreciated.
Sep 12, 2010 | Nikon COOLPIX S8000 Digital Camera
Camera stopped taking pictures
Same thing happened to me a while ago. I was in a panic. I turned it on and off several times...no change. Finally, I turned the camera to the off position, took the battery out of the camera for about 30 seconds and put it back in again and it worked fine. No problem since.
Jul 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon a85 only works with no Memory Card.
Here are some simple things to try first for a camera that won't power on. Recommend trying the first step listed for the A520:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Nov 26, 2007 | Canon PowerShot A85 Digital Camera
Nikon Coolpix 8700 Digital Camera Logo
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
