Question about LG Washing Machines
MY WD-8050FH Lg intellowasher 7kg has the no drain signal?
I have an LG intellowasher 7kg and the no drain signal is apperaing? can anybody give me any suggestion of what i can do before calling/paying someone to have a look?
SOURCE: my lg intellowasher 7kg WD-1059 FB will not pump
Pump motor is probally shot, Mine is 4 years old I'm replacing mine again. Yes I've replaced it twice
Posted on Feb 23, 2009
SOURCE: LG WD-8050FH LOUD noice when spinning & 'funny' burning smell!!
I had the same symptoms and almost dismantled the whole machine to locate the root of the cause. The issue was one of the 3 arms of the spider (like a 3 spoked wheel that connects to the rear of the drum and holds it in place and provides the drive shaft to through to the motor at the rear), had snapped after weakening from corrosion due to undissolved washing powder building up in the grooves.
To prevent this, do a hot wash every few weeks to dissolve the powder, don't think your saving the environment by using only cold washes, this should be in every washing machine manual to save the environment from waste from un-economically repairable appliances.
The burning smell was the unbalanced drum leaning heavily on the rubber shroud on the front between the drum and the outer casing. The replacement spider part was only about AU$60-80.
To check if this is the problem you may be able to tell by opening the door, and reaching in from the front with your palm up about a hand distance till you go past the rubber shroud and just touch the stainless steel drum. Grip it gently with your four fingers and pull towards the front (to you) about 1cm or two, with about as much force you would need to open the machine's door. Rotate the drum approx one third of a rotation and repeat, do this 3 times and you should feel one point give more than the others.
If no luck try again in sixths of a rotation, you can gauge the distance by the 3 plastic agitators attached on the inside wall of the drum.
Note: get a price on labour first to replace the spider, as this will be probably more than half way to a new machine, and then the cost of the part, and the call-out fee if you can't get it into a service centre.
What's the point of having a long lasting stainless steel drum when the key part that connects the drum to the motor is a weak cast iron / alloy part.
Ask your local service person what units have quality parts before buying a new machine.
ps: the loud noise is probably the cracked arm rubbing or the unbalanced drum hitting the sides and making the machine jump.
Hope this all helps!
Posted on Apr 06, 2010
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
SOURCE: cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Posted on Jun 30, 2010
SOURCE: 7KG WD-8050FH LG Clean Master
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Posted on Aug 14, 2010
How do I clear the CL code on the display of the washing machine lg intellowasher 7kg WD-12235FB
The Child Lock function on your washer has been enabled. Press the options buttons simultaneously for 3 seconds to reset.
May 11, 2015 | LG Washing Machines
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
My washing machine turns on but will not start. It will only make a click sound then another click sound. Please help
Your timer swicth is defective or fuse inside but check first the cord if it not broken before you go to fuse and timer
Jun 15, 2012 | LG Washing Machines
Cant open door
Apr 25, 2009 | LG Washing Machines
7KG WD-8050FH LG Clean Master Front Loader (5 stars) No Drain ....won't drain or spin
Jul 14, 2008 | Washing Machines
Washing Machines Logo
339 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
