Question about Cameras
Nikon CoolPix won't turn on after taking memory card out
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
  • 69 Answers
SOURCE: Memory Card Capacity for Nikon P4
you can put a 16 gig in without any trouble
Posted on Dec 20, 2008
robmcd27
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
Lardzor
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Posted on Sep 13, 2009
Gort007
  • 1187 Answers
SOURCE: camera shows memory card is write protected. how
The SD or SDHC memory card has a slide switch to lock / unlock the card. Move it to the unlock side.
If the card is an MMC (Multimedia Card), it is not supported.
Posted on Oct 09, 2009
Testimonial: "it worked thank you"
My nikon coolpix s6300 won't let me view the pictures i have taken on the camera.
I can only offer this: (sorry if it does not help)
When the micro USB Cable is plugged into the camera you MAY be able to take photos. The camera MAY work normally EXCEPT for the MONITOR or Screen. The screen is TURNED off when you plug in the cord.
Nov 01, 2017 | Nikon Coolpix S6300 Hd Digital Camera
Nikon coolpix S8100 won't power on even with new battery.
10 replace batteries or recharged very well the batteries.
2) clean very well the contacts batteries from oxide, dust, dirty. or corrosion
3) batteries loaded in WRON direction
4) batteries is NOT the right type
5) poor contact between battery and cover , clean and adjust it .
6) Memory card slot/battery covert is open
God bless you
Jul 31, 2012 | Nikon Coolpix S8100 Gold Digital Camera...
Nikon Coolpix L105 Camera won't read a memory card
Your camers is set that way change your settings go to menu
May 25, 2012 | Nikon Coolpix L105 12.1mp 15x Optical Zoom...
My Nikon Coolpix S3100 won't turn on
I had the same problem, and many other people have had this issue. The camera sat for too long, and the battery fully discharged. It needs to be reset. In order to do that, remove the battery and memory card. Replace only the battery, and plug it in. You should see a green light flashing to the right of the LCD screen. That means it is now charging. Replace your memory card, and let it charge before trying to use it.
Apr 30, 2012 | Nikon Coolpix S210 Digital Camera
All of a sudden, my MacBook says "cannot recognize format" of some of my Nikon Coolpix L18 pix and won't download my last 10 pix, nor any more that I take. It downloaded the previous 20 pix...
Sounds like the memory card in the camera has gone bad, or the camera has glitched. Try replacing the card. If it still does it, the cam has issues.
Aug 04, 2011 | Nikon COOLPIX L18 Digital Camera
I use some new alkaline batteries but the camera (Nikon 5600 coolpix) doesn't go on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 11, 2011 | Nikon Coolpix 5600 Digital Camera
I can not take pictures because the camera displays write protected
Check that if the side bar of your memory card is at unlock? if it won't help, format your memory card by your computer
May 23, 2011 | Nikon Coolpix 4500 Digital Camera
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
I downloaded my pics off my memory card to my laptop now the memory card is reading when i turn on my camera memory card is write protected what does that mean? i have a nikon coolpix s60. when the memory...
Look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 22, 2010 | Nikon COOLPIX S60 Digital Camera
No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
Jan 23, 2008 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
