The cord came out of the inside of the keyboard. i am unsure which direction the connector goes back on.
  • 8,404 Answers
It should be "keyed", i.e. only connect one way. Look at the plug closely to detect any difference.
If not ... try it one way ... if it doesnt work - turn it over.
I'm sure you will not do any damage to either as long as you dont force anything.
On the other hand ... keyboards are pretty cheap.
Let me know what happens.
a
Posted on Sep 26, 2009
Why does only half of my keyboard play
most likely a defect in the conductors or connector of the wiring from inside the keyboard to the cord
open the bottom of the keyboard, check the connector to see if the flat wiring is fully seated
unless this is the trouble it is time for a new keyboard
before you buy one use a keyboard from a friend to be sure this is the trouble
Sep 13, 2014 | Computers & Internet
Sharp er a470 was changing faulty power cord and disconnected the keyboard, now after I put everything back together it won't come on. Checked power with multimeter, everything seems to be fine
Did you wear static protection while you were working inside? That's not for YOU, it's for the electronics. They're wicked sensitive to static.
BUT... it might also be the case that you just didn't plug everything back in perfectly. Go back inside, wearing static protection, and doublecheck every connector inside. EVERY connector, even if it's on the other side of the board.
Jul 26, 2014 | Computers & Internet
My laptop shuts down in 5-10 mins.
Instructions
Purchase a new fan for the Sony Vaio model you have by checking the owner's manual of your computer or consult the Sony website for the correct part number.
Remove the power cord from your computer and then remove the battery. Unlock the battery and slide it from the bottom of the laptop. Allow it to sit for 5-10 minutes after removing the battery.
Turn the computer with the left side facing toward you and locate the only screw found on the left side and remove it. Remove the panel by sliding it toward you and set it aside.
Slide the panel covering the power buttons to the left and detach the ribbon cable connecting it to the motherboard and then remove the panel gently.
5
Remove the keyboard by unscrewing the small screw directly above the keyboard. Once the screw is removed, gently lift the keyboard and detach the small cord connecting it to the motherboard. Set the keyboard aside.
6
Remove the plate under the keyboard by unscrewing the three screws and lift the plate out.
7
Disconnect the cooler fan from the motherboard by pressing the connectors in and removing them from the sockets. Once the connections have been removed, lift the cooling fan up out of the computer.
8
Replace the old fan with the new one you purchased and attach the two connectors. Reinstall the metal plate back on top of the fan and attach the screws.
Jan 10, 2013 | Dell Inspiron 1545 Notebook
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
How to remove keyboad on a laptop hp g61
The procedure is straignforward. For step by step intructions download the service manual from
http://h10032.www1.hp.com/ctg/Manual/c01868653.pdf
Please rate this solution. Let me know if you have any problems or questions. Thanks.
Jun 09, 2011 | Computers & Internet
When the power goes off, and back on, a majority of the time there is a rapid clicking noise where the power cord goes into the back of the reciever. If i unplug it, or alter the direction of the plug,...
It could be that you have a loose fitting power supply cord. Try replacing it and make sure it's pushed in FIRMLY. Also, blow away any dust or debris that maybe in the connector causing a poor connection. If it's actually sounding like it's inside the metal chasis of the amp. DO NOT TAKE ANY RISKS and un plug it, you will then HAVE TO tak it in...unles your a trained electronics guru type.
Good Luck
Sep 03, 2010 | Marantz SR6001
Got a used Compaq Pressario SR1303wm and need to set up correctly
Monitor into Small Blue connector at back.
If Mouse and keyboard are Round and not Rectangular in shape then that's a PS/2 Mouse and keyboard. Purple goes into Keyboard slot at back. Green goes into Mouse at back. Watch for the design as the pins inside each one need to be inserted accordingly.
If they ARE rectangular then that is a USB connection. On the back connect the keyborad and mouse to the top two. Again, only going to insert one ways.
Jun 26, 2009 | HP Compaq Presario SR1303wm PC Desktop
Replacing Secondary Water Valve? How does it hook back up?
white connector on the valve connects to the icemaker fill line
gree connector on valve to water in the door
blue connector to the filter or house connection
May 17, 2008 | Refrigerators
Power plug on laptop not working
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system1.gif.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
Feb 05, 2008 | AMD BALANCE A535 NOTEBOOK MOTHERBOARD WITH...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
