Question about Philips Brilliance 200WP7ES - Flat panel display - TFT - 20" - widescreen - 1680 x 1050 / 75 Hz - 30... 20 inch Monitor
I have a philips brilliance 200w6 lcd moniter that has no sign of power, i have checked all and replaced all capacitors, got power going though all the boards in the back but still no sign of power, no led light ...nothing please help as i love this moniter
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Scle193, What happened that you needed to replace electrolytic capacitors? Why ??? Still no sign of power??? Did you pay attention to polarity when replacing the capacitors? Did you document you work with a digital camara to make sure that you could put it back together without having any leftover parts or unconnected cables. Have you measured the dc voltages at the output of the SMPS? Have you checked any and /or all onboard mounted FUSES?? What was the original complaint you had with this monitor? Have you tried to get a service manual or schematic from Philips? Get back to me with info
if you can. lmistyrel @aol.com bye for now. louie12fix
Posted on Sep 26, 2009
TV just went blank. My brother-in-law has a LG LCD tv. He is going to give it to me. Would it be worth it for me to try and get it fixed. It is about 5 yrs old.
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
Dec 13, 2010 | LG 32LD550 32 in. LCD HDTV
Moniter is not on . i checked the power is comming to the moniter. no picture no lights, screen is not on i mean moniter totally dead.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 04, 2010 | Hanns.G Corporation JW-199DPB 19" LCD...
My monitor does on power on
In my monitor ( Philips 150 S) , the message come very frequently as " OSD main controls locked", what is the solution
Apr 07, 2010 | Philips Brilliance 151AX Monitor
Moniter's menu option gets automatically selected whenever i open my moniter screen
arpanpallar, If you are certain that pc not causing problem, then hp internal "switch-mode-power-supply" could be the problem. Noisey DC source will cause very strange things to occur on screen!! You or technician will need to look for common visual signs of bad capacitors on the circuit board. Do some reading in my and other CCFL back-lit lcd monitor tech's fixya profiles. 12fixlouie
Mar 12, 2010 | HP Computers & Internet
Philips Brilliance 200w6cs Backlight off Green LED ONN
Check to see at one of the pin on the inverter board has 12vdc feeding it. No bad capacitors? Pictures?
Nov 29, 2009 | Philips Brilliance 200WP7ES - Flat panel...
Lcd monitor problem
The inverter board can be in the power supply inverter board combination,.you should check the power supply for bad capacitors first.
Please post back what you find.
Nov 25, 2009 | Philips Brilliance 150P4CG (Beige) 15" LCD...
Philips brilliance 200w monitor no video
nice anecdote, fixing things from far is not easy, a t.v.-technician right in front of the actual screen could tell more- but they don't come for free, alas. hope that people's idea about problem solving lead up to you fixing a problem yourself - hey this here is for free - to sort wxperts, one needs feedback! thx alot
Jul 22, 2009 | Philips Computers & Internet
Monitor will appear to come on a "no signal" sign flashes up then the screen goes black. If you press the on off swich the green light will come on briefly then go to orange and then disappears completely...
could be a number of possibilities, lcd backlight is going bad, bad capacitors on the power board, lcd cable needs to be reseated, power board needs to be replaced. Best possibility would be to take it to a repair shop and see what the costs would run to fix it.
If its more then the cost of a new monitor then get a new monitor cause you would get the warranty.
Jun 28, 2009 | Westinghouse L1975NW Monitor
Philips Brilliance 200WP7ES - Flat panel display - TFT - 20" - widescreen - 1680 x 1050 / 75 Hz - 30... 20 inch Monitor Logo
461 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
