Question about Canon PIXMA MP190 All-In-One InkJet Printer
I refilled the ink as instructed, but the printer still doesnt want to print. when I push any button the letter "E" displays on the screen. what should I do?
  • 6 Answers
SOURCE: reset Ink levels for canon mx310
To Reset the Canon Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Any problems contact me on charmed_halliwell@hotmail.co.uk
Posted on Feb 23, 2008
canon printer are very little number of print if you printing best photo
Posted on Aug 06, 2008
  • 4 Answers
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
SOURCE: Refilled ink cartridges not recognizby printer.
Hi, I have the same printer. There is no such thing as a special chemical added to the ink. The cartridge has a memory chip and remembers the number of droplets used by each cartridge. This is Canon's way of getting you to buy THEIR INK at outrageous prices. You need to reset the ink level indicator on each cartridge that you refill. Then be sure to refill the ink cartridge before it gets too low. Check out a CIS system that are available for this brand of printer. Don't buy into this special bogus ink story.
Posted on Jan 16, 2009
  • 164 Answers
SOURCE: Coloured printer with black not printing?
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
Why lexmark 3550 won't print after installing new ink cartridges
Check your manual for instructions about this type of problem. Are you using the ink cartridges meant for your printer? Sometimes using refillable cartridges instead of the manufacturer's cartridges can cause the printer to still think the cartridges are empty, and display an 'on-screen' message that they need to be replaced, which could stop the printer from engaging. I have a Canon Pixma printer, installed refillable cartridges, and now the unit displays a 'cartridges are empty' message on PC screen; but the printer still works. The system just recently went into a non-printable mode displaying a more convincing message that the black cartridge is EMPTY, and completely stopped printing. The solution to this: press and hold the Stop/Reset button for about five seconds, and it overrode the issue and started printing. Moral of the story, maybe its best to just buy the manufacturer's printer cartridges.
Jul 26, 2014 | Lexmark Office Equipment & Supplies
Canon mp390 manual
We suggest you first attempt the basic/universal Canon ink level reset procedures before attempting any of the more advanced procedures provided on our Inkjet411 site*
A. Standard Ink Level Reset Procedure (printers without LCD display):
[ Refer to the 1st support video: http://inkjet411.com/?page_id=62 ]
1) At computer screen message, select 'Stop'/'Reset', 'OK', or 'Resume'.
....or....
2) Select 'Stop'/'Reset', 'OK' or the 'Resume' button (triangle-circle icon) on your printer for 5-8 seconds:
- Printing may continue under the 'ink out' condition.
B. Standard Ink Level Reset Procedure (printers with LCD display):
[ Refer to the 2nd support video: http://inkjet411.com/?page_id=62 ]
1) Install cartridge and start print job.
2) After first message appears, click 'OK' to continue. Printer should start printing.
3) If second message appears and printer's LCD screen displays error code "E", then DO NOT click 'CANCEL PRINTING'.
4) Press and hold down 'Stop'/'Reset' button (triangle-circle icon) on your printer for 5-8 seconds. Printer should start printing.
If you are able to produce a self test print, this is good since it illustrates that the cartridges are electrically stable...if you observe any 'E' or 'V' error states (i.e. E13 or V162 for example), this may indicate there is possibly an internal electrical problem with one of the ink cartridges. Refer to your user guide if E/V error messages are displayed.
*If, after following the suggested ink monitoring/level reset procedures, you still have an error condition which prohibits regular printing, then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
To verify the Canon printer is functional, install a brand new cartridge in it - this will 100% confirm whether your refilled, compatible or remanufactured ink cartridge is faulty or not.
For information on North American Canon ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 12, 2013 | Office Equipment & Supplies
I have refilled my color ink. After it prints 20 pages it lights up the "color ink" button meaning it's out of ink and starts printing poorly. I tried refilling twice with new ink - same thing happened.
Try this, it will reset your counter.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset
Sep 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Having trouble with ink refills
Many aftermarket companies have inferior parts in their ink cartridges. Stay with the genuine cartridge for yours. To save money refill your own. They can be refilled at a low cost and the cartrige will reload about 7 to 9 times before it no longer any good to use any more
Jul 04, 2010 | Canon I960 InkJet Photo Printer
How do I re set the cartridges after a refill on my Canon PIXMA MX320?
Hi there
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset
Ink level notification:
1. Push “resume” for 5 seconds for canon For MPXXX you must enter to service
Mode.
2. Push Power switch then remove power cord.
3. Insert plug power cord while pressing “power switch” at the same time.
4. Push Start/reset by step 2 continue Wait display shown “0′
5. Push + change display from “0′ to “1′
6. Push colour button 2 times
7. Push Power switch again, Printer will print 1 page
8. Open cover
9. Unplug power cord
10. Take out ink cartridge #40 and #41
11. Insert plug again
12. Push power switch
13. Open cover (scan cover)
14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
With the printer powered off but connected to a power source, press the Power
Button while pressing and holding the Stop/ Reset button.
When the Power is lit, press the Stop/Reset button two times while pressing and
Holding the Power button.
When releasing the Power button and the Stop / Reset button (regardless of
Order), the printer will move into a service mode. (Waiting for menu selection)
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Canon PIXMA MX310 All-In-One Printer
My hp printer f4280 display E on the start/copy screen and colore print catridge display empty but i refilled it. printer does not print. what is the problem?
my printer after i refill still shows empty and not printing.please give me the solution i cannot afford to always buy a new cartridge.thank you
Sep 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Lexmark X2550 ink cartridge refill
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Mar 31, 2009 | Lexmark X2500 All-In-One Printer
Printer cartridge is a refill and does not seem to be recognized
Maybe you can try to reset the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Dec 23, 2008 | Lexmark X2500 All-In-One Printer
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon MP150
7) Press the power button twice and the printer will print a some stuff (if this page doesn't print by itself, press the "color" button once and the test page will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
Aug 07, 2006 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP190 All-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
