Need a recovery disk to restore computer to factory setting file/windows/system32/config/system status Oxoooo14c windows failed to load because the system registry file is missing, or corrupt
  • 8,404 Answers
Contact your laptop manufacturer on the WWW.
Posted on Sep 26, 2009
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Tip
How to do System Restore when the computer doesn't even boot to Safe Mode in...
System Restore is assumed to be the best method to recover the system from Registry or System file errors. Its easy to perform and is effective, no doubt. But what happens when the system doesn't even boot to the desktop, neither in Normal mode, nor in Safe Mode. How do you do a System Restore then. For Vista and Win 7 users, its a piece of cake, since the WinRE provides them the direct option to System Restore from the installation/repair CD. But what for the XP users?
The following method is very useful and serves as a bliss for Windows XP users to recover their system from crashes due to Registry or System file failures. All you need for the method is a Windows XP installation CD. (This is not a re-installation process. All data and settings are intact after the operation.)
Step 1: Boot to the Recovery Console
  • Insert the Windows XP CD into the computer.
  • Turn the computer off.
  • Setup the computer to boot from cd: either by pressing F2, F9 or Delete to go in BIOS and changing the boot sequence or by pressing F12 on Dell computers to launch the Boot Device Menu.
  • As soon as you get the message 'Press any key to boot from the cd', hit enter.
  • Wait for the Windows Setup to initialize
  • At the Welcome to Setup screen press R to repair windows using recovery console.
  • You will be prompted to choose a Windows installation. Press 1 on the top of the keyboard and then press Enter.
  • You will be prompted to enter the Administrator password. Press Enter if no password was set.
Step 2: Accessing the Restore points.
Type the following commands in the Recovery Console.
cd system~1
If you get an Access Denied error:
  • Type the following commands to change the directory to c:windowssystem32config:
    cd windows
    cd system32
    cd config
  • Rename the system branch of the registry. That will allow us to access the system restore folder from inside the Recovery Console. In case the process fails and you want to perform a Windows Repair you will need to rename system.bak to system again.
    ren system system.bak
  • Type exit to leave the recovery console and to restart the computer.
  • Go back into the Recovery Console and repeat Step 2.
cd _resto~1
If the _resto~1 folder exists, inside it there are several folders named RP1, RP2. These are restore points. RP1 is the oldest restore point. You can use dir to view what RP folders are available. If there is no _resto~1 folder or if there are no restore points inside it:
  • Type the following commands:
    cd
    cd windows
    cd system32
    cd config
    copy c:\windows\repair\system system
  • If you are getting a file not found error try:
    copy c:\windows\repair\system.bak system
  • Then type the following :
  • copy c:\windows\repair\security security
  • copy c:\windows\repair\software software
  • copy c:\windows\repair\sam sam
  • copy c:\windows\repair\default default
  • exit
  • You will be able to boot into a altered version of the operating system. Backup your files from the c:Documents and Settings folder and then reinstall the operating system.
Step 3: Choose the most convenient RP folder.
Supposing we have RP3 available let's type in:
cd rp3
Change the directory to snapshot:
cd snapshot
Step 4: Restore the main registry branches.
If you are being asked if you want to overwrite type in y to agree.
copy _registry_machine_system c:\windows\system32\config\system
copy _registry_machine_software c:\windows\system32\config\software
The following commands are most of the time optional however the process might not work if they are not executed
copy _registry_machine_security c:\windows\system32\config\security
copy _registry_machine_sam c:\windows\system32\config\sam
copy _registry_user_.default c:\windows\system32\config\default
Type exit to reboot the system. Start the computer normally.
Thanks,
Abhishek
on Mar 22, 2010 | Microsoft Windows XP Professional
I have a Dell Inspiron 1525 stuck in windows boot manager file \windows\system32\config\system status: 0xc000014c info: windows failed to load because the system registry file is missing or corrupt ...
Here's part of an article on how to replace that registry file:
Look in the C:\windows\system32\config\regback\ folder.
There should be copies of the registry files stored inside that folder.
They are backed up periodically and stored in that folder.
If you create a MiniWin, BartPE, or a Linux Live CD, you can start the computer from CD and move the file system to the required folder, C:\windows\system32\config\.
Apr 15, 2013 | Dell Inspiron 1525 Laptop Computer PC...
\windows\system32\kdcom.dll Missing or corrupt Kernel debugger
Try tapping F8 at bootup to enter safe mode, read your manual to see if you have a recovery partition on your HDD. You didn't post the model so I have no clue.
If you can enter safe mode you need to try system restore, not last good know configuration.
If you see last know config on your screen, then you should also see safe mode.
So you need to run in safe mode, and run system restore, or run the recovery mode if you have a recovery partition on the HDD.
If none of these work, then you only have three options, go to Avira.com, download the rescue disk, burn it to a CD and run it in DOS, this is before windows boots. Now if malware corrupted the DLL, Avira will kill it, but there is a chance it can't clean it and will destroy the files,DLL, and windows won't boot. So now you have to do below.
The other option is you need to download windows, what ever version you have, if you have win 7 home 32bit, then you have to download it, and burn it to a DVD. Then try a repair, if a repair does not work then you need to reinstall windows, and then install all the drivers like, (chipset, video, sound, lan, wifi)
This option, you can contact Acer and see if they have a recovery disk for you.
Good luck.
Apr 01, 2013 | Computers & Internet
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Hp paviliondv2050us wont start
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
I have deleted svchost.exe from windows xp
Dec 02, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
280 people viewed this question
David Payne
David Payne
