Question about Philips Brilliance 109S Monitor
What is the best colour adjustment to have monitor on for output printing? Image management or photo retouch?
  • aquashell007 Sep 28, 2009
    Thankyou geekinator, i should of been more specific. The monitor is a 109 E5, not the S model that seems to come up in my searches.
    The monitor control settings are: general use, image managment,photo retouch, sRGB, and user settings. Not sure which one to use so have set to 'factory settings' for general use' There is no 'smart setting' as with the 'S' model. I realise sRGB is mainly used for internet imagery but could i get away with using it in my out sourced printing that is usually converted to CMYK?
    Sergeant:
    Novelist:
  • 183 Answers
Hello there aquashell007.
Here's your GEEK-steer ...
I infer from your question that it's your belief the quality and/or accuracy of your monitor's output has an effect on the output of your printer, etc. This is not so. Not anymore than by having your monitor turned off, your printer would print a black sheet. In fact, the only thing your monitor's output has an effect on is its viewer ... you.
However, this does bring up an interesting related issue: How can you know if your monitor is truly diplaying orange ... oranges, and green ... greens, and light ... lights, and so on. You can, with calibration software.
There are many freeware choices available to you. "Monitor Calibration Wizard" is one I've used occasionally in the the past over a period of many years.
It is my hope you find this GEEK-steer ... illuminating.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Craig
Posted on Sep 26, 2009
Testimonial: "Was very helpfull, thankyou. "
  • Craig The Geekinator
    Craig The Geekinator Sep 26, 2009
    @aquashell007
    After reviewing your original question, I now see that I clearly misunderstood it.
    I believed your question was asking what was the best setting within your monitor's configuartion setup (e.g., On-Screen-Display OSD) which could improve (1) printing, (2) image managment, and (3) photo retouching. I blew right past your first question mark as if your were ticking off three seperate output/processing related activities. Hence my reply discussing that whatever you adjust, or see on, your monitor has bearing on what any output will look like.
    I now see that you were asking which of the two setting names ("Image management" or "photo retouch") is better.
    But I'm still not clear if you were you referring to which of these two choices is best to select within a monitor related setup, or one of your printer setups?
    Nonetheless, now I hope I haven't just discombobulated you even further as I apologize for the confusion on my part.
    "Today's (still) the best day of my life ... and NOW you're (still) part of it!"
    Craig The Geekinator Sep 29, 2009
    @aquashell007
    Thanks so much for posting back. Moreover, thanksX2 for the follow-up detail that listed all your adjustments options, as well as ... "I realize sRGB is mainly used for internet imagery but could i get away with using it in my out sourced printing that is usually converted to CMYK?".
    Hallelujah! I can now see that I actually did initially strike the right chord, despite my bit of follow-up confusion. We both were going in precisely the same direction, towards the same destination, but from two different paths (if you will).
    YOUR OBJECTIVE: You want as accurate a color representation as possible of the materials you produce, and have that match what your print shop prints. In other words, what YOU SEE, is what you GET.
    Which is partially why I suggested the "Monitor Calibration Wizard"? Because it can help calibrate your monitor to display as true a STANDARD color spectrum as possible. This is done not merely to make its viewer feel warm & fuzzy about what they are seeing, but much more importantly to achieve the objective of a STANDARD of UNIFORMITY. Thanks to you having mentioned your sRGB setting option, it's doubtful you need trouble yourself with "Monitor Calibration Wizard". Why? Because by using the sRGB setting you should essentially realize the same objective. A review of this passage from your monitor's documentation should bring you the remainder of the distance to that destination we both were heading towards:
    [QUOTE] [my emphasis added]
    sRGB is a standard for ensuring correct exchange of colors between different devices (e.g. digital cameras, monitors, printers, scanners, etc.).
    Using a standard unified color space, sRGB will help represent pictures taken by an sRGB compatible device correctly on your sRGB enabled Philips monitors. In that way, the colors are calibrated and you can rely on the correctness of the colors shown on your screen.
    Important with the use of sRGB is that the brightness and contrast of your monitor is fixed to a predefined setting as well as the color gamut. Therefore it is important to select the sRGB setting in the monitor's OSD.
    To do so, open the OSD by pressing the OK button on the front of your monitor. Use the down button to go to Color temperature and press OK again. Then move the down button to go to sRGB and press OK again. Exit this OSD.
    After this, please don't change the brightness or contrast setting of your monitor. If you change either of these, the monitor will exit the sRGB mode and go to a color temperature setting of 6500K.
    [END QUOTE]
    == SUGGESTIONS ==
    • If you capture any images from a sRGB capable device, be sure it is set appropriately.
    • Make mention to your printer that you use the sRGB standard.
    • Always insist to your printer that they produce verification sample(s) of any large jobs prior to full production (I'm sure you probably already know this though, and so should he, but sadly, this still requires mention).
    • If you don't get acceptable results between product and print, you may want to then consider a go at "Monitor Calibration Wizard".
    Via-con-Dios and Godspeed - Craig
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
My new canon mg5200 printer prints washed out colours compared to what is on the page i am printing from. I have changed the print resolution to high and that has helped a small amount. Can you please tell...
I think you will have to use the printer's "color management" to adjust the output to match what you see on the monitor screen. Go to Canon's website, it explains everything you need to alter the colour profile for your printer.
Sep 03, 2011 | Canon Cameras
How to edit picture?
Hi
You don't say which operating system you are using.
Photo Editing requires Photo Editing Software.
To do basic photo editing (cropping, rotating, flipping, adjust brightness, adjust contrast, adjust image size, adjust colo(u)r, adjust exposure, adjust size, adjust red eye) you can use free, built-in software that comes bundled with Windows and Microsoft Office such as: Paint, Microsoft Picture Viewer and Windows Photo Gallery.
In increasing order of editing functions:
Windows Photo Gallery: Fix > Auto Adjust, Adjust Exposure, Adjust Colour, Crop Picture, Fix Red Eye
Microsoft Office Picture Viewer: Picture > Brightness & Contrast, Colour, Crop, Rotate, Flip, Red Eye Removal, Resize, Compress.
Paint: Image > Flip/Rotate, Resize/Skew, Crop, Invert Colours, Adjust Attributes, Clear Image, Opaque.
In Paint you can also use additional tools to manipulate the image or add or delete shapes, text and colour (with a selection of writing or drawing implements): Free Form Select, Select, Fill with Colour, Magnifier, Brush, Text, Curve, Polygon, Rounded Rectangle, Ellipse, Rectangle, Line, Airbrush, Pencil, Pick Colour, Eraser/Colour Eraser.
In Windows Photo Gallery you can view and edit the same image in either of these 3 programs by clicking Open.
For more advanced photo editing, you can use the bundled software that comes with digital cameras such as:
Adobe Photoshop Elements
ACDSee
Picasa
Photo Studio
For more advanced, professional standard photo editing you must buy expensive Photo Ediiting and Graphic Design software such as:
Adobe Photoshop
Adobe LightRoom
Adobe Illustrator
Adobe InDesign
CorelDRAW
Corel Painter
I hope this helps.
Aug 26, 2011 | Computers & Internet
HP c5280 only prints green photos. All other printing is fine. I have put in new hp ink and photo paper. I have tried printing both from computer and with computer unplugged. A print from a website on...
This Problem is based on the Color Management so , The Perfect Solution for this problem is open the Photo or image etc in Adobe PhotoShop then goto Enhance->Adjust Color->Remove Color Cast , after removing the color cast , create a new layer for adjusting brightness , contrast & etc , then finally goto Image Size and change the DPI from 72 to 300 then save the image as JPEG or PNG etc , after saving the image close the Photoshop and open the image using Windows Photo Viewer and take the printout which will come as it is in the System
May 23, 2011 | Office Equipment & Supplies
How do I balance colour on the printer for photo printing?
Have the photo printer run a test/alignment page.
Make sure you are not running out of one color.
Anytime the image runs heavy on one color typically means another color is empty or low and not blending properly.
You can also check the settings to see if it is printing in Draft/Normal/Best Mode. Depends on the settings and application used to control this. Best uses more ink and of course provides the best image. Photo quality paper if you want the best looking pictures. Printing on standard bond will cause some bleeding and saturate the paper. (Looks feels wet) This will give the image a slight blurring dull look.
Depends on the quality of the paper used also.
Hope this helps!
Oct 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Access to retouch photo program.
Drivers and manuals can be found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11463
I am not sure if the CanoScan has a retouch program with it, but if you use Windows, you probably have Picture Manager which will let you retouch and resize and crop picture. Right-click the image you would like to open and select open with Picture Manager
Nov 17, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Photoshop and the R1800
I had the same problem and read everything I could find about it. Finally after tinkering around, I discovered that printing everything using "Photo Enhance" setting produced the best pictures. Also, I use a calibrated monitor and print through Photoshop Elements 5. Lots of Luck! Cyndy
Jan 28, 2008 | Epson Stylus Photo R1800 InkJet Printer
What are the effects of Adobe RGB?
Adobe RGB enables more vivid color reproduction, for Adobe RGB is capable of more color space than sRGB. It offers more flexibility than sRGB on image processing and image retouching. Please note, however, a normal PC monitor cannot realize the color reproduction effect, for the available color range of the monitor is restricted by its specification. Further, an image with Adobe RGB ICC profile may be reproduced in poor color depth unless color management is provided in advance. Meanwhile, there may be cases that the Adobe RGB effect is realized in printing out, as some colors can be reproduced by a printer.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
Philips Brilliance 109S Monitor Logo
240 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
