Question about Samsung SGH-A877 Impression Cell Phone
The touch part still works but the screen doesn't light up or display anything, any suggestions?
The microwave doesn't work at all. no display, light, anything
Plug a lamp in the wall receptical in place of the microwave oven, if okay! it means the main fuse in the oven has blown. There are a number of reasons why this happens, a bad fuse, door switch that has malfunctioned, "common" cracked high voltage diode, shorted capacitor, and an open magnetron. I suggest a professional.
Mar 09, 2012 | Panasonic Microwave Ovens
I droped my lg virgin rumor touch and The touch screen cracked but when I turn it on it stays black. What could I do?
If you won't see anything on screen,check if the phone is booting or turning on,if it turns on,display is probably the problem.but if doesn't power?software problem is the main cause.and with this,need to replace LCD as well as touch screen that was damage too.
If your mobile has a warranty,you can bring it to the service center for spare parts replacement.If you try to open it and it's under warranty,this will void you warranty and unable to benefit free of service charge.
Jun 15, 2011 | LG RUMOR Cellular Phone
I have a sony DSC T300 that the back touch screen doesn't display any video. It lights up and I makes the noise when I touch where the scroll arrows are (when in play mode) or where menus should be (in...
Hi your unit has lens unit defectiveness. It won't reset itself initializing. The noise come from initializing IS unit defect. your local repair shop would charge around $45 to 115 depend on what they really want to charge. thanks and best regard!
May 25, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
Touch screen doesn't work
Remove the battery and insert it again after 30mins.
then switch on ur 4n..if it doesnt work,..try by pushing the touch screen towards the Display.
May 21, 2011 | Samsung Star GT-S5233 Cell Phone
I have dropped my phone and now the touch screen doesn't work how do i reset my phone when the touch screen doesn;t work
if your phone's touch screen has not developed any cracks, it could have damaged the touch interface internally, i would suggest getting your phone checked at nearest Samsung authorized service centre
May 09, 2011 | Samsung Wave S8500 Smartphone
I have a Android 2.1 Tablet PC X220 flytouch2 with GPS and Webcam and for some reason the power saver display option is basically turning off the screen instead of dimming it. so my problem is i can not...
Have you tried plugging it into the charger? If it's plugged in, the screen should dim but not turn completely off for at least 10 seconds. If it doesn't work, try covering the light sensor on the front of the tablet, so that the screen will brighten until you can change the backlight setting in Menu -> Settings -> Display.
Apr 30, 2011 | Coco 10"2 Touch Screen Android 2.1 Tablet...
My touch screen is not working
Have you tried starting from scratch.Go to Tools then
Settings then Display,make sure the Screen Shot is Enabled,hope this works for you.
Oct 06, 2009 | Garmin nuvi 255W GPS Receiver
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
Samsung SGH-A877 Impression Cell Phone Logo
75 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
