Question about GE Profile JTP18 Electric Single Oven
Ge profile jtp18 wall oven. in the middle of replacing the electronic clock control. wiring slightly different than original. i have installed and control appears to work. however, the oven elements do not heat at all
  • 15,935 Answers
Was there a wiring schematic with the new clock?
Have you checked the thermal fuse?
Check it and let me know.
Thanks!!
Posted on Sep 26, 2009
GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
I used the oven in the house we just purchased (a GE wall oven JTP18 and after I turned it off a fan kept running. Is that normal?
Yes, the program and thermostat calls for the fan to cool the electronics, without that you can loose the electronic boards. Normally the fans will shut off once temps drop to 200 degrees Fahrenheit. Enjoy your new home.
Jul 08, 2011 | GE Profile JTP18 Electric Single Oven
Error code FO
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Oct 17, 2010 | GE Profile JTP18 Electric Single Oven
Ge profile convection oven giving error code F7. What parts do I need
Hi
Thanks for using FixYa. Error F7 means that the function pad button is stuck or the clock has gone bad. If you are unable to unstick the button then to resolve this issue you’ll have to replace the electronic range control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | GE Profile JTP18 Electric Single Oven
GE profile wall, single, Get a
Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
Thanks
Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Dead trivection oven by ge JT9300h1ss
This model has issues with the power input controller board, usually caused by surge following a power failure... board is $285 from GE plus $90 or so to install after paying a $100 service call. Replacment part is special ordered and generally takes a week or so.... have 2 of these ovens... ask me how I know.... LOL
May 30, 2009 | GE Profile JTP18 Electric Single Oven
F7 error
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
May 03, 2009 | GE Profile JTP18 Electric Single Oven
F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Apr 22, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
32 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
