Question about Samsung HL-R6167W 61" HDTV
How to change bulb
How do i change the bulb i can't seem to figure how to take it out
    President:
  • 632 Answers
You'll need a 5.91 inch screwdriver and a pair of gloves.
  1. Remove the screws securing the lamp cover at the back of the unit.
  2. Remove the lamp cover.
  3. Remove the screw securing the lamp.
  4. Separate the bulb from the engine by holding the handle and pulling it out.
  5. Follow the steps above in reverse order to install the new lamp.
Posted on Sep 26, 2009
I have a 1995 GMC Sierra pickup and my tail lights don't work
there is a big green fuse in the fuse box under the hood. cost about 6 bucks. replace that
Jan 30, 2012 | 1995 GMC Sierra
Headlights need changing
Your headlights are not sealed beams. You have to find the light. You have to twist the bulb bracket a quarter of a turn in order to unlock it. You pull the bracket out and change the bulb. Do NOT touch the new bulb with your bare hands. The oil from your skin will cause the halogen bulb to get tooo hot and will burn out. When you change your bulb, you might as well change both of them.
Jul 10, 2010 | 2006 Chevrolet Equinox
Change fog light bulb on mk2 golf gti big bumper
need to change mine too...really cant seem to figure out how to do that!! been through the haynes manual as well..doesnt say a thing about the fog lights..did you finally manage with it? any clue that could help me out?
Jun 23, 2010 | 1990 Volkswagen GTI
Removal of headlight assembly to change headlight bulb on 2007 gmc yukon xl. I see the two screws above but can't tell if there is more to removing assembly. seemed easy initialy, but can't figure it out....
I am not familiar with the model but the vehicle handbook usually contains instructions and diagrams on bulb replacement. If stuff has to be removed to change the bulb the book will usually tell you to take the car to your nearest dealer.
Many headlamp bulbs need a strong light, a mirror and a great deal of patience...
Feb 27, 2018 | 2007 GMC Yukon
NEED TO CHANGE BULB BUT CAN'T SEEM TO FIGURE OUT HOW TO GET INTO CASING
First open the rear liftgate (not just the glass). This will expose the two screws that secure the housing of the lamp to the body (it also exposes the connector plug which, obviously, you should unplug). After removing the two screws, separate the rubber housing from the LED lamp itself....and there you have it!
The third brake light might be a sealed lamp, so the entire brake light must be changed. you can't just replace the bulbs.
I hope this helps.
May 21, 2009 | 2001 GMC Yukon XL
Replace Bulbs in Headlight. 2008 Dodge Avenger
there is 2 bolts on top 1 top outer and 1 top front behind grill, u need to remove the top center black cover and 1 bottom side outer need to remove the inner finder liner to get to the 3rd bolt.
hope that helps, it is stupid
Mar 09, 2009 | 2008 Dodge Avenger
Changing the rear brake light in a 1989 chevy celebrity/
in the trunk there plastic butterfly nut you got to remove all of them pull lends of change bulb thanks pierre
Jan 11, 2009 | 1989 Chevrolet Celebrity
Changing Headlight bulb
okay it is actually really easy althought they wouldn't want you to think so. It took me and my husband like 3hours to figure it out. But we did and now were like duh. If you open your hood and stick you hand down the front to where you are right behind the headlight if you feel around you will find that there are like caps over the place where you should be able to get your bulbs out. what you have to do is get a small flat head screw driver and pri the cap off and take out your bulb. It sounds worse than it is i promise and the only hard part is getting your hands on the caps
Oct 05, 2008 | 2004 Chevrolet TrailBlazer
Front turn signal 1990 Buick Century
Hi Angela, what you need to do is look under the hood and basically locate the backside of the light that your wanting to change the bulb in. You'll see a wiring harness going to that area. Give the plug a twist and pull the old bulb out.
Jun 13, 2008 | 1990 Buick Century
Light bulb
I was just looking at these fans. One site said to use the palm of your hand to turn the light cover 1/2 trun. I can't remember which way to turn.
May 16, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Samsung HL-R6167W 61" HDTV Logo
98 people viewed this question
Jerry Greenberg
Jerry Greenberg
