Question about Casio Algebra FX 2.0 Calculator
My problem is that i cannot get a correct syntax
My problem is that i cannot get a correct integration from a certian funkiton. i have a given V(t) in vectorform and each line has now to be iintegrated to get the stemmfuction: first one is 4*sin(5*x+3)
obvious its pretty easy to get the stemmfunction but i need to know how it works with the calcutlato, the solution of the calculator always has some kin of pii in it... thx in advance
  • Casio Master
  • 7,993 Answers
I do not speak Goethe's language, so I am not sure what your stammfunktion really means. I expect you will not hold it against me if I do not address your real question.
The syntax for a definite integral is as follows
Integral sign ( function expression , starting point, end point, tolerance )
No need to put the differential dx. Do not forget the commas.
Hope it helps.
Posted on Oct 03, 2009
My calculator is not work he has on but not show any think.what happened
Posted on Nov 09, 2012
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
How can i solve integrals with ALGEBRA FX 2.0 PLUS
The syntax for the evaluation of definite integrals (integrals with boundary limits) is as shown on the screen capture below.
$ (function , variable , lower bound, upper bound)
By default the name of the dummy variable is x. If you use another name, the variable must appear as an argument of the function, and as variable.
Mar 13, 2012 | Casio Algebra FX 2.0 Calculator
Whenever the command expand, diff or integrate are use it comes up with wrong argument. I have tried to clear all variables and default the set up but to no avail.
I believe you are using the wrong syntax for the commands.
diff ( function, variable) Example: diff (sin(x^2), x) sgould give you 2.x.cos(x^2)
expand( will expand an expression that has parentheses: expand( (a+b)^2) will give a^2+2a.b+b^2
Integrate $
$ ( tan^-1(x), x) willl give x.tan^-1(x) -(1/2) ln ('x^2+1')
Check the syntax of a command before using it. You will find the list of all comands and their syntax in the reference manual.
Aug 22, 2011 | Casio ClassPad 300 Calculator
How do i intigrate powers of sine and cosine on the ti89?
  1. In Home screen, Press [2nd][F1] (F6) to open the CleanUp menu.
  2. Press [1:Clear a-z] or [2:NewProb] and press [ENTER].
  3. After the calculator displays Done, Press the [MODE] key.
  4. Navigate the pages till you find the option Exact/Approx.
  5. Select EXACT.
  6. Return to the Home screen and type in your integral, using the syntax $( f(x), x) and press ENTER. Here the dollar sign stands for the integral sign.
  7. If you want a definite integral, the syntax is $( f(x), x, lower_bound, upper_bound).
Here is a screen capture with a few examples.
Jun 23, 2011 | Texas Instruments TI-89 Calculator
When i do my integration problems i am getting my answers in decimal form. for example {S((lnx),x,1) = 0.}
What are you trying to do? The syntax you use depend on what you want to achieve.
Indefinite integral : Integral( ln(x),x) gives the correct answer xln(x)-x
Definite integral : Integral(ln(x),x,1,2) gives the integral of ln(x) between x=1 and x=2
Definite integral between 1 and y : Integral (ln(x), x,1,y) gives the correct expression yln(y)-y +1
By inserting the =0 you are in fact assigning the result of the integration to value 0, and the calculator calculates the integral and assigns 0 to it. This is what my TIVoyage 200 PLT gives me:
{Integral((lnx),x,1) = 0.} returns {x.ln(x)-x+1=0}
which is an equation.
Apr 17, 2011 | Texas Instruments TI-89 Calculator
How to install package manager in ubuntu?
A package manager is a program that installs and uninstalls software, and keeps track of all the components each piece of software needs.
Dpkg is the Ubuntu package manager dpkg is a medium-level tool to install, build, remove and manage Ubuntu packages. The primary and more user-friendly front-end for dpkg is dselect.dpkg itself is controlled entirely via command line parameters,which consist of exactly one action and zero or more options. The action-parameter tells dpkg what to do and options control the behavior of the action in some way.
Now we will see all the available commands for dpkg with examples
1) Install a package
Syntax
dpkg -i <.deb file name>
Example
dpkg -i avg71flm_r28-1_i386.deb
2) Install all packages recursively from a directory
Syntax
dpkg -R
Example
dpkg -R /usr/local/src
3) Unpack the package, but don’t configure it.
Syntax
dpkg --unpack package_file
If you use -R option is specified, package_file must refer to a directory instead.
Example
dpkg --unpack avg71flm_r28-1_i386.deb
4) Reconfigure an unpacked package
Syntax
dpkg --configure package
If -a is given instead of package, all unpacked but uncon-figured packages are configured.
Example
dpkg --configure avg71flm_r28-1_i386.deb
5) Remove an installed package except configuration files
Syntax
dpkg -r
Example
dpkg -r avg71flm_r28-1_i386.deb
6) Remove an installed package including configuration files
Syntax
dpkg -P
If you use -a is given instead of a package name, then all packages unpacked, but marked to be removed or purged in file /var/lib/dpkg/status, are removed or purged, respectively.
Example
dpkg -P avg71flm
7) Replace available packages info
Syntax
dpkg --update-avail <Packages-file>
With this option old information is replaced with the information in the Packages-file.
icon_cool.gif Merge with info from file
Syntax
dpkg --merge-avail <Packages-file>
With this option old informa-tion is combined with information from Packages-file.
The Packages-file distributed with Debian is simply named Packages.dpkg keeps its record of available packages in /var/lib/dpkg/available.
9) Update dpkg and dselect’s idea of which packages are available with information from the package pack-age_file.
Syntax
dpkg -A package_file
10) Forget about uninstalled unavailable packages.
Syntax
dpkg --forget-old-unavail
11) Erase the existing information about what packages are available.
Syntax
dpkg --clear-avail
12) Searches for packages that have been installed only partially on your system.
Syntax
dpkg -C
13) Compare Package versions version numbers
Syntax
dpkg --compare-versions ver1 op ver2
14) Display a brief help message.
Syntax
dpkg --help
15) Display dpkg licence.
Syntax
dpkg --licence (or) dpkg --license
16) Display dpkg version information.
Syntax
dpkg --version
17) Build a deb package.
Syntax
dpkg -b directory [filename]
18) List contents of a deb package.
Syntax
dpkg -c filename
19) Show information about a package.
Syntax
dpkg -I filename [control-file]
20) List packages matching given pattern.
Syntax
dpkg -l package-name-pattern
Example
dpkg -l vim
21) List all installed packages, along with package version and short description
Syntax
dpkg -l
22) Report status of specified package.
Syntax
dpkg -s package-name
Example
dpkg -s ssh
23) List files installed to your system from package.
Syntax
dpkg -L package-Name
Example
dpkg -L nagios2
24) Search for a filename from installed packages.
Syntax
dpkg -S filename-search-pattern
Example
dpkg -S /sbin/ifconfig
25) Display details about package
Syntax
dpkg -p package-name
Example
dpkg -p nagios2
Please check if this is any help for you.
Regards.
May 26, 2010 | Computers & Internet
Integration, too few arguments
I reset my calculator and this solved the problem. To reset your calculator press [2nd], then [6] (Mem), press F1 (reset), Select 3 for all memory, and select Yes.
Oct 23, 2008 | Texas Instruments TI-89 Calculator
Windows XP driver for the integrated sound
http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1010&SubCatID=104
that should be the adudio driver your looking for
there is also a link at the top "driver agent" that will scan your computer and find the right drivers for all your hardware
May 30, 2008 | Syntax SV266A SKA KT266A Motherboard
Casio Algebra FX 2.0 Calculator Logo
201 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
