Question about Black & Decker CHV1400 Bagless Handheld Cyclonic Vacuum
Battery replacement I tried to follow the owner's manual instructions, but I have been unable to remove the battery cover.
  • goat123 May 18, 2008
    I can not remove the battery cover.
  • Anonymous Jul 16, 2008
    We also had the same problem--couldn't remove the battery. The manual appears to be generic, and the removal instructions are not applicable to model 1400.
I have opened CHV1400 by removing two screws that are visible when you remove the "accessory" from its holder (located underside of the vacuum). After removing the 2 screws, I had to pull the green colored part by exerting slight force. You will now see the battery. It is held down by 2 more screws which are easy to remove.
Posted on Aug 15, 2009
    Problem Solver:
  • 10 Answers
Call a service centre for advice, ie 01543 275048.
Posted on Dec 21, 2007
How change battery on irobot 655
The battery replacement procedure is the same for 500 and 600 series.
  1. Remove the side brush screw and side brush.
  2. Remove the 4 screws to remove the bottom cover.
  3. Remove the battery.
  4. Install the replacement battery, with the iRobot logo facing up and charge overnight.
More items...
Replacing the Roomba 500 and 600 series battery. - iRobot Customer ...
https://homesupport.irobot.com/.../replacing-the-roomba-500-and-600-series-battery.
Feb 04, 2018 | iRobot Vacuums
My battery has suddenly stopped charging owned sweeper for about 6 months and followed directions for charging very specifically can I get a r e placement battery
Be certain the charger is working before you look to replace the battery. The manufacturers web site or the owners manual should have a part number for the battery.
Mar 29, 2015 | Vacuums
I just adopted a Bissell 1719 spot cleaner from my sister-in-law but they don't have the manuals. How do I change the battery? I don't see any removable clips, just screws in the unit housing
Good evening,
Please see the below link for the user guide/manual to this unit:
http://www.retrevo.com/support/Bissell-1719-Vacuums-manual/id/10659bh140/t/2/
This unit should include a charger for the battery. Below is the instructions on how to charge and maintain the battery.
If you need to actually replace the battery, the instructions below show the process:
Just a quick note, these units do come with a Ni-Cad battery, which should last you at least 5 years (closer to 6 or 7), and make sure that dispose/recycle the battery properly.
This can all be found in the manual (link provided at the top). I hope this helps, and please let me know if you need clarification. Please rate this solution!
Thanks,
~PCF
Mar 15, 2011 | Bissell 1719 Spot Lifter 2X® Handheld...
How do I remove the battery in a Dustbuster chv1400 for replacement? I have removed the two screws and removed the cover, but I'm unable to figure out the retaining clips for the battery. Of course I don't...
That model looks similar to my DB200. Instead of the screws, the underside has a latch/panel that you remove. Place a screwdriver in the two slot-like holes that face each other (one at a time) and the 'door' should pop out. Mine was a little stiff and I broke one of the retainers inside. Shouldn't be a problem. Sourcing a replacement battery 'pack' is what I'm doing now.
Dec 12, 2010 | Black & Decker Vacuums
How do you replace the 'after filter' in the electrolux guardian?
1. Press latch and open the door that covers the tools.
2. Squeeze clips at front of tool tray, lift and remove.
3. Remove filter.
4 Replace filter.
5. Replace tool tray and close door..
Instructions can be found in the Renaissance manual, which you can download from the following site. Go to "older models", find Renaissance and click on it, then click "download". Instructions are on page 9. The Renaissance is basically the same model as the Guardian.
http://www.aerusvacuums.com/support/manuals/
Nov 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
I think I need to replace the main battery in my small floor vac - the one that can be hand held like a dust buster or work like a small floor vac. I need to know how to remove the battery and replace it...
I see my sense of humor is not appreciated...it was only a joke. Anyway, here is what you do: First, slide the battery cover off the bottom of the hand held unit. Remove the battery from the motor housing by pressing the tab on connector “A”; this releases the battery from the motor housing. Plug the new battery (LC-R064R2P) into connector “A”. When installing the battery the wires have to go in first and they must be placed in front of the battery or you'll never get the battery cover back on.
Oct 16, 2009 | Vacuums
Removing the battery
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear.
Apr 18, 2009 | Dyson DC16 Root 6 Bagless Handheld...
How to change belt on bissell proheat powersteamer
There is a video on the Bissell website on how to do this, click here for the link:
Video
Jun 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
Black & Decker CHV1400 Bagless Handheld Cyclonic Vacuum Logo
366 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
