Question about Scanport Computers & Internet
Scanner I have a scanport 2030 color scanner but I don't know how it works. I bought it years ago and forgot about it. I found it this week. Is it still usuable or so outdated it would be of no use. I do not have manuels and really don't know how to start it or print photos.Any help is appreciated. Jane Staton 4648 Oneonta Cutoff Albertville,Al 35950 tjstaton@charter.net
  • 883 Answers
SOURCE: Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
Posted on May 29, 2007
SOURCE: Printer will not print in Black at all
Actually guys, I figured out that because I had been using the same ink cartridge for so many years that the print heads were terribly dried out. I bought from SuperMediaStore.com (its a site run by Yahoo!) $3/$4 ink cartridges, both black and color (they charge too much for shipping though), and I have absolutely no problem printing right now.
Look around online, and buy cheaper, maybe up to $10, cartridges, but do NOT buy these stupid OEM cartridges!! Most cartridges sold on the internet are up to OEM standards.
That worked for me, hope you guys have good luck!
Posted on Sep 24, 2008
SOURCE: Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Posted on Oct 15, 2008
louislevel_2
  • 374 Answers
SOURCE: thread from the needle wraps around the bobbin case and knots
hi! there,
wrong set up made this thing goes wrong,well
its good things to go to internet, on address
type www.youtube.com type on search
box type "sewing macnine" there some
instruction follow specielly set thread and
bobbins and some otrhe sewing feature that
you can learn.have a nice day dont forget to
rate me, thank's
Posted on Apr 10, 2009
SOURCE: Trampoline net
Hope this helps. The trampoline net will either have a sleeve for flexible poles to form a ring at the top or there will be at least four obvious "loops" to hang from the poles. Then you need to sew the net to secure it to the mat/trampoline itself with rope. A good idea to buy new rope to do this as it wears with use. I have replaced my securing rope with "tie-down" rope from the sporting good department. The soft nylon kind seems to wear better. To sew: use a good knot to secure it to the underside of the trampoline (spring/Loop) then simple go through the net at the bottom skip a few holes come back through the net and go down around the bottom of a spring hold. repeat all the way around.
Posted on Aug 17, 2009
Hi; I have Canon IR 2030, but when I press the scanner online tab on the screen it showing me a phrase saying ( cannot shift to the online state ), so can anybody find me the solution please as soon as...
hi every one i have canon ir 2030 but i cant install the scanner of it if you have any slution please let me know
you cooperation will be higlly appracaited in advance.
please mail to me @ csmkbl@yahoo.com
Feb 03, 2011 | Canon imageRunner C3100 Copier
Scanner not found.
first check all your wires make sure nothing has come loose.
unplug the power supply wait a minute and re power scanner.
Also, turn off you PC and restart it.
retest your scanner
if it still does not work then..
next try reinstalling your scanner driver software on your computer.
If these beginning steps do not work please write back for further diagnosis.
Mar 26, 2010 | HP Scanjet 4370
Forgot my PUK CODE
Hello, you need to contact your service provider for that
Sep 26, 2009 | Nokia 6126 Cellular Phone
How to scan in text formate in ricoh2030
You need an OCR (Optical Character Recognition) program such as Textbridge or Omnipage ect. The program should use your scanner to scan and then read the page(s) and save as text.
Jun 11, 2009 | Ricoh Aficio IS420 Flatbed Scanner
USED TO WORK WITH WINDOWS 98 NOT NOW WITH XP
www.driversguide.com may help you, you will need to enrole but it costs nothing and they do not pester you
Or try running the program in 95 emulation mode which is part of the XP tools
May 25, 2009 | Computers & Internet
Looking for driver
Hi, my suggestion for this is to go to www.driverguide.com, I know they have popups and you have to signup, but it is free, and when it was a driver i've spent weeks trying to find, for some reason they have always had some of the craziest stuff, like those dialup modems that had brand names that were bought and sold at least a dozen times. Driverguide will take a bit of time but it will be worth it when you get the driver.
Nov 02, 2009 | Scanport GL 715A 15.1" Flat Panel LCD...
Scanport 2400 scanner
Try this link. The readme.txt tells the details of the drivers.
ftp://ftp.scanport.com/scanport/drivers/
Feb 29, 2008 | Office Equipment & Supplies
Computers & Internet Logo
37 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
ray gallant
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
