Question about Motorola Mobility RAZR V3
How do you set up your sync connections - Motorola Mobility RAZR V3
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
Futher sync issue
Did you try doing a hard reset to the device
Jun 05, 2008 | LG KE800 Smartphone
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
TO BE ABLE TO CONNECT MY HTC HERO PHONE TO PC
Step 1: Connect your phone
Grab your phone and the USB cable that came with it. If you need some additional help setting up and using your new phone, see Windows Phone 6.5 basics for more information.
Step 2: Download the sync software for your computer
Choose the sync software for your computer's operating system, which you can download here:
  • • If you have Windows Vista or Windows 7, your sync settings will be managed through Windows Mobile Device Center.
  • • If you have Windows XP SP3, your sync settings will be managed through ActiveSync which can be downloaded from MS website.
    I hop this helps
Jun 19, 2011 | Computers & Internet
My htc desire will no longer sync with my PC it asks to insert disk into drive E
Your solution
Setting up HTC Sync to recognize your phone
After installing, set up HTC Sync to recognize your phone.
1. From the Home screen, press MENU, and then tap Settings > Accounts & sync.
2. On the Connect to PC screen on your phone, tap HTC Sync and then tap Done. Your phone attempts to find HTC Sync on your computer. Wait for a few seconds for the process to finish.
3. If your phone displays a message indicating that it's unable to find HTC Sync, try disconnecting and reconnecting the USB cable, and then repeat step 2.
4. When the Phone Connection Wizard is displayed on your computer, click Next.
Enter the name you want for your phone, and then click Finish.
Check the HTC Sync icon at the bottom-right side of your computer screen. If it appears green in color, that means your phone has successfully connected with your computer and HTC Sync recognizes your phone
If still no go try this .
Unplug the phone from the PC, restart both the phone and the PC. When the PC is done booting, plug your phone in and see if the autorun box pops up.
still if nogo try this .
you have to select disk drive (when plugged in via notification area) to be able to view the drive in windows and htc sync to use htc sync.
May 27, 2011 | HTC Desire Cell Phone
How to copy htc3300i contacts to pc/ samsung monte
1.Download HTC Sync 2.0.40 and install 2.Connect your HTC and PC 3.Tab connection setting in HTC Sync display menu (when you connect to PC Sync menu will automatically display) 4.Tab contacts.All the contacts in your handset copy to PC.
Mar 06, 2011 | HTC P3300 Smartphone
Trying to set up iphone not used itunes before
this covers all apple i products
When you connect your device to your computer, items automatically sync according to your preferences set in iTunes. You can, for example, enter email addresses of friends and family members on your computer, connect your device to sync, then unplug it and tap a friend's email address on the touchscreen to email them.
You can sync
  • Contacts-names, phone numbers, addresses, email addresses, and so on
  • Calendars-appointments and events
  • Notes (sync with Mac OS X Mail* or Microsoft Outlook)
  • Web bookmarks
  • Music and audiobooks
  • Photos
  • Podcasts
  • Movies and TV shows
  • Applications
  • Ringtones (iPhone only)
  • Books
  • iTunes U content
Note: On iPad, you can also sync documents via File Sharing with apps that support it.
You only need to set which items are synced in iTunes on your computer once. After that, just connect your device to start a sync.
Contacts, calendars, notes, and bookmarks are synced from (or to) your computer, so if you add, change, or delete them on the device, they are changed on your computer, and vice versa. You can also sync contacts with your Yahoo! or Google Address Book.
Email-account settings, music, movies, TV shows, podcasts, and photos are synced one-way, from your computer to your device (though you can import photos taken with iPhone to your computer and you can transfer purchases from your device to iTunes). Using an iPad, you can send photos back to your computer (typically captured on iPad via the Camera Connection Kit).
If you like, you can set your device to sync with only a portion of what's on your computer. For example, you might want to sync only a group of contacts from your address book, or you may want to sync only songs from certain playlists so you don't fill your device with your music.
* Syncing is over USB only and on a Mac requires Mac OS X v10.5.8 or later.
Set up syncingYou use iTunes on your computer to choose which items to sync. Make sure you have the most recent version of iTunes (on a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.)
1. Connect
  1. Connect your device to your computer using the included cable. By default, iTunes opens automatically.
  2. Select your device in iTunes under Devices on the left-hand side and click the Info tab.
2. Choose which items to sync
Click the respective tabs in iTunes to specify which media and information you want to sync from your computer to your device.
For more information about syncing your device with your computer, see the User's Guide:
3. Sync
Click Apply in the lower-right corner of the screen. Your computer syncs with your device according to your settings.
The first time you sync your device, you are asked if you want to merge data, replace data on the device, or replace the data on your computer. When you choose to merge information, any differences between the data will be mingled together. If you choose to replace information, information from either the computer or device will overwrite the information on the other. These options can not be undone. After that, anytime you connect your device to your computer, iTunes opens and syncs with your device according to the settings in iTunes.
You can adjust sync settings any time your device is connected to your computer.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on your device or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
Dec 05, 2010 | Cell Phones
How to sync .ipa files from comp to iphone thru itunes ?
when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
Setting Up Syncing You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
Step 1: Connect iPhone or iPod touch
  1. Connect iPhone or iPod touch to your computer using the included cable. You can connect the cable from your computer directly to iPhone or iPod touch, or connect the cable from your computer to the Apple Universal Dock (available separately) and put iPhone or iPod touch in the dock. By default, iTunes opens automatically.
  2. Select iPhone or iPod touch in iTunes under Devices on the left hand side and click the Info tab.
Step 2: Set Up Which Items Are Synced Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
For more information about syncing iPhone with your computer see the iPhone User's Guide:
On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
For more information about syncing iPod touch with your computer:
On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
Step 3: Sync iPhone or iPod touch Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Apple iPhone Smartphone
PC Driver
there is no need for drivers for sync u just need active sync installed in WINXP if u dont have active sync install it from www.windowsmobile.com or see if it came with ur mobile in a cd and Windows mobile device centre in WIN VISTA that is bundled in the installation already u just find it by typing in search WMDC or in All programs u can look for it after u launch it just connect ur mobile thru usb cable provided and go in ur mobile pda start>settings>connections>usb connections set ur device for sync not mass storage and then press ok open the active sync software in xp or WMDC in Vista and it will automatically connect ur device then sync ur device as req
pls let me know if i can help u more in this and pls rate fixya if i have fixed ur problem
Feb 25, 2009 | i-mate SP5m Smartphone
Cannot connect using LG internet cube software
I had the same problem but now i have found the solution for it. Its not the software its the phone. Go to your Phone Settings hit Connectivity and then Usb Connection select Data Service and now connect your phone to the pc and select connect in Mobilesync and it should work. After you are done using MOBILE SYNC you can simple go in settings once again and choose mass storage for any downloads!!!
Dec 17, 2007 | Computers & Internet
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
