Question about Grinders
I had a concrete deck poured around my inground pool, two days later i see a hair line crack in it, two more days later theres another they start at the wall and make there way to the edge of the pool. they seem to open up to the width of a pack of matches the cardboard width there not big but i see them as clear as day and im worried about the winter time and water getting into them,I was going to cut them deeper with a hand grinder and pour that epoxy into the crack, or how about pouring cement into it? keep in mind its coloured and stamped the color is pewter (darker Gray) Please help me Im sure there is some way to fix it! Signed Cracking up Gary
    President:
  • 1,723 Answers
Call the contractor back and ask him what you just asked me. I would demand some response too.BE careful how you approach them. Be very polite and professional, but direct and unwavering. You want some answers and deserve them. Your cement should not be cracking like that, it has a bad base, not level, and is not supported correctly.
Posted on Sep 26, 2009
Is there an instruction manual for these cleaners out there?
Here is a copy of the users manual for these pool cleaners:
http://www.zodiacpoolsystems.com/Product-Archive/Cleaners/~/media/Zodiac/Global/Downloads/H05551.ashx
Sep 12, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray vac will not go in reverse, what is wrong
Your backup valve has probally gone bad. You just need to pull this out of the line and take it to a pool store and have the internal replaced. They will do this for just the price of the part in most places.
Jul 11, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Goes in circles
you have a clogged line. disassemble and clean it very good
it should work fine after cleaning all ports out
May 24, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac Pool Cleaner for Inground Concrete: Our Ray vac worked well for years but now it tends...
If your automatic pool cleaner is going in circles, you might want to check your backup hydro-timer. If it is releasing most of the water out of the discharge hoke, you might need to replace the defective jet gear assembly. Also, make sure that the transporter jet is not plugged. Check your hose to make sure that there are not any obstructions that would prevent proper movement.
May 18, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
I had a 20X40 inground pool installed on a slope. the pool company had to build up the low side to make it level using the dirt from the hole. the pool looks good but the concrete on the end that had to be...
I think they are using what you did as an excuse to cover their oops, They should stand by their installation and fix it for nill. if the concrete is not standing up to the p[ool , then they did not engineer the installation and make it good for the support of the pool
they drive cars on 6 inches of concrete, and if installed correctly it will last forever
Apr 12, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
My Ray Vac is also floating in a nose dive position. I ajusted flow valve, speed,cleaned filters and nothing works Please help
You have a head float inside the head that has probally cracked and filled with water. You can take this apart yourself or your pool store will probally do this for you for just the price of the part. Then they can look over the whole thing for you. Just remove the head and bring it into the store. Good luck.
Jan 31, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Suction line replacement
we cut a 12" hole.
David
May 23, 2009 | Pool & Spa
Runs in a small circle
A couple of things to check. 1. sometimes the hose at the back of the head will develop a small hole or crack where water will escape and cause the vac to run in circles.
2. if the head is getting old, you might have enough wear that the little wheels on the bottom stay mostly in one location, pushing in one directon.
May 15, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Grinders Logo
106 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
