Question about HP OfficeJet 6210 All-In-One InkJet Printer
I opened the top to put in new ink & the left side hinge came apart now it won't close . I can't see how to put the hinge back together..help...
jaylex
  • 417 Answers
SOURCE: Putting printer back together
without seeing them will not know what parts you are trying to describe but if you type in the Google search bar HP parts surfer and then goto that web site, enter a country then search for your model of machine you will be able to look at diagrams of the various parts and locations on screen.
Hope this helps
Thanks J
Posted on Jan 19, 2008
Bappa170873
  • 505 Answers
SOURCE: I open the top to
Make sure the drum is clean. You may have to realign the print cartridge by going to the printer properties.
Thanks
Posted on Oct 17, 2008
357reaper
  • 75 Answers
SOURCE: broken hinge....where do i get it and how do i put back together
hi,you can try contacting hp about this.they may send you a new one.as far as fixing this it would be more costly than the printer is worth sry.
Posted on Mar 04, 2009
AllenTech08
  • 54 Answers
SOURCE: Looking for HP L7680 Manual. My top roller fell apart...
You can download the manual here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=2512009&lang=en&
Posted on Mar 26, 2009
TechyDrood
  • 2072 Answers
SOURCE: hp 6310 repair hinge
Generally the hinge will fall into a groove when lifted up. If it will not close you can generally lift the lid a bit higher and dislodge the hinge from these grooves and it should close.
Posted on Oct 20, 2011
How do I close the door to my printer? It seems that one of the hinges is broken apart.
If it's broken, you can't get it back together and your prrinter won't work with "door" opem look for the sensor which indicates that door is open, stick it somehow so it should show door closed and used happily forever your printer. If this trick is not possible, no way, take your printer to an HP repair center and get installed a new door.
Aug 27, 2015 | HP Officejet 6310 All-In-One InkJet...
When dryer finishes it just keeps on beeping
Instructions
Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up.
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes.
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
Jan 10, 2013 | Haier HDY6-1 Electric Dryer
Can't get the door back on
Instructions
Jan 09, 2013 | Dryers
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
Hinge is broken on my lexmark X6500 so cover won't close
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Jul 23, 2011 | Lexmark X6570 InkJet Printer
Double oven top door will not close
you need to change you oven hinges, change them as a pair cost around £40.00 to buy, not a hard job to do
Apr 07, 2010 | GE Profile JTP56 Electric Double Oven
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
HP 3310. My hinges are broken
Posted by fmoo on May 15, 2009 My hinges also broke ink cartidge door stuck open. HP rep online chat never was able to understand problem.
SOLUTION: open up printer using torx T10 bit. It is pretty tricky take off right side panel. Disconnect all cords, remove paper jam clean out panel in rear. Remove two silver colored screws behind this panel. Remove two black screws on rear of printer next to the hinges. This will allow the middle panel to swing down and be gently lifted back and away from the printer. You need to release the tab on the side panel underneath the open ink cartridge door. Use a putty knife or some other stiff thin metal object lift it gently and it will free the side panel. Disconnect the multi wire connector at rear of printer, then disconnect the three multconnector ribbons noting where they connect. You will replace them in the opposite order. The entire scanner can now be removed (also a little tricky). With the ink cartidge door open (I assume you can't close it yet), push the outermst piece or end of the hinges uptowards the scanner deck (This is hard - the part is stiff) while this tab is pushed in slide the scanner up off of the hinge. TIP: Stand the whole printer on its left side (the printer is now perpindicular to your work area) this will take the weight off of the hinges.
Now with the jammed hinges uncovered, you will find a screw under the front side of the lid hinge. The hinge is slotted so you can reach through it with your Torx bit. Remove the hinge (it now just lifts out) Pull the hinge pin out and take out the black piece of plastic. Do this for both hinges. Just get rid of the worn out plastic piece (it hardly looks worn, and you might as well take the springs out too. Put the hinge together without the spring and the plastic part.
Now reassemble the whole thing. Your printer should work fine, but you will need to prop the thing open to change cartridges in the future.
Aug 15, 2008 | HP Photosmart 3310 All-In-One InkJet...
Freezer door opens just a tiny bit when i shut the fridge side anybody know how to fix this
to be honest with you, close the door more gently. there are air vents between the frig and the freezer, when you close the frig door its forcing air into the freezer which in turn forces the door open some. the air has to get out so thats what it does. i hear this complaint alot.
Nov 27, 2007 | Frigidaire FRS3R5EMB Side by Side...
I dropped and it came apart
Solved it.
If you need to take it all the way apart, here's the scoop:
Get the top cover off by popping it up at the hinge side (this is what pops when you drop it)... then at the charging end, slide the top towards the hinge to slip the clips out from under something.
the folding mic tells the board it is open by a small z-shaped piece of plastic. The skinny end of this fits into a tiny hole in the bottom of the case and the fat side slides up and down in a little round space over on the side of the case. There is a rubber button with a dark piece that sits on top of the round space. The dark side of the rubber piece presses against a round circle on the circuit board and tells it whether the mic is open or closed. Once you put it all together, you have to press the board down pretty firmly to tell if it is all working.
Then put the volume buttons back in place and slide the top back on.
Jan 12, 2007 | Motorola Mobility H700 Wireless Headset
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
