Question about HP PhotoSmart 7760 InkJet Printer
Will not power up, no function at all - HP PhotoSmart 7760 InkJet Printer
Machine wont power on, cord and power going to it are good.
Could be a bad power supply or bad function board. EBM has both parts available 800-832-6522. You would have to remove plastic cover over the function board and check for voltage on the wires from the power supply (where the on/off switch is to the function board. If no dc voltage is present at function board, then power supply has failed. Power supplies are wearing out due to age.
Mar 16, 2015 | IBM Ww1000rf Wheelwriter Refurbished...
How to use the exp key
I think it is case of mistaken identity. There is a function called the power function. The general form of it is a*(b)^x or a times (b) to the power of x. a is just a constant factor (not equal to 0) and b is the so-called base ( also different from zero). Personnally I call this function the power function, but you find it is often called the exponential function.
The exponential function e^x is similar to the power function. The main difference is that its base is a certain irrational number called e (=2.718281828...).
What you want to do, as far as I can guess is to calculate 2000*(1+0.12)^20.
Simplify your life and set 1+0.12 as 1.12, and type in 2000 [*]1.12^20=
1.12^20=9.646293093. Multiplied by 2000, this gives you a final result 19 292.58
To enter the the power use the key marked as [X^y], [Y^x] or [^]
Jun 26, 2012 | Sharp EL-531VB Calculator
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
My HTD HD7 has suddenly decided to not respond to any touch functions whats so ever. The screen nore the three function buttons at the bottom register any touch. The remaining buttons, power, volume and...
I'm having the exact same problem.
An hour ago I was using my phone fine, and then it randomly shut off and turning it on again I have no touch function, while the volume and power are fine.
I've done everything recommended, much like you and having no luck :/
Oct 10, 2011 | HTC HD7 Cell Phone
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
RESETING THE FULL ABSORBER
Waist reset code
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down POWER button, let go of the RESUME button and then press the
RESUME button twice in succession. Then let go of the RESUME button and POWER
button.
(Each time you press the RESUME button, the indicator's color toggles between orange
and green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the stipulated number of
times to execute the desired service function listed below.
press 4 times indicator light should be green, this Clears the waste-ink counter.
4) After selecting the service function, press the POWER button. The green indicator
lights and the service function will be executed.
(After the respective function is executed, the printer returns to the service function
selection mode.)
To cancel printing after it begins, press the POWER button.
The Power lamp will blink for a while and then stay lit. You can then select
another service function.
Oct 22, 2009 | Canon Office Equipment & Supplies
Auto Power Off function DiMAGE E223
Yes, the auto power save functions to save power. The camera shuts itself off after 3 minutes after the last operation
Sep 19, 2005 | Konica Minolta DiMAGE E223 Digital Camera
Is the auto power save function employed?
Yes, this camera has an auto power save function to save power.The camera turns off the displays and unnecessary functions if an operation is not made within a minute. (Power Save Function).To restore the power, press any button or key, or turn the exposure mode dial to another position.The length of this period is selectable from 1 min., 3 min., 5 min., or 10 min. in the section 1 of the setup menu.The LCD monitor always turns off if any operation is not made in a minute, and this period cannot be changed.If no operation is done within 30 minutes, the camera shuts itself off. Pressing the power button resumes the camera operation from this condition.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
HP PhotoSmart 7760 InkJet Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
